C32 with Vogtland springs
Thanks PUREMS(Mike)they came out great,just the drop i wanted,i have #4 pads in the rear just for rubbing issues, does it take time for the springs to settle or is this it?what do you recommend?
so you guys know i got the spring from PUREMS they have a variety of springs ,suspension kits,rims,etc,very knowledge people.
... Perfect color car and perfect wheels.... How much did they run you, if you don't mind me asking?Eric...
and if no pics are coming up int the C32 forum,like FrankW said i have them posted in W203 forums now too.
That's great... Larger wheels and less weight... What about overall diameter? Small differences can lead to large changes in speed/odo readings...
Eric...
Finish: Silver w/Machined Lip
Bolt Pattern: 5-112
19x8.5 Front $249 each
** Lightweight: 27.8lbs. **
Availability: In Stock
19x9.5 Rear $259 each
** Lightweight: 30.0lbs. **
Availability: Low Stock
ASA ST4
19x8.5 F
$249
19x9.5 R
$259Finish: Silver w/Machined Lip
Size Selected: 19x8.5 Front
Price: $249 each
Estimated Availability: In Stock
Recommended Tire Size: 225/35-19
Wheel Offset: +25mm
** Lightweight: 27.8 lbs. **
Size Selected: 19x9.5 Rear
Price: $259 each
Estimated Availability: Low Stock
Recommended Tire Size: 255/30-19
Wheel Offset: +31mm
** Lightweight: 30.0 lbs. **
Additional Specs
Bolt Pattern: 5-112
Finish Warranty: 1 Year
Country of Origin: South Korea
Construction Type: LP Cast/Shot Peened
225/35-19 Front
255/30-19 Rear
if i went to 255 it will solve the problem,and i could go back to a thinner pad which i beleive would be #2.
I have tracked the car recently,and found that the fronts woar the wost on the outside of the tire wall the most,and the rears had the rubbing on the tire wall itself,imagine all the small letter on the sidewall were scape off,and the sidewall has turned a blueish,puple color,caused by all the heat buildup.this happens all the time on the sidewall of my racebike,but i have never been able to acheive this in a car.
As for the rubbing, I guess the grafted CLK front end on the C55 has more fender clearance than on the other W203's.
I will give you the first deposit!
