Exterior lamp switch and dash lighting (C55).
1. Are the icons around the exterior lamp switch supposed to be lit with lights on, so you know what position you are in at night (e.g. if you want to switch on/off fog lamps, go back to auto, etc)?
2. Most other cars I have been in have a rheostat to control dash and instrument lighting level. Is there one?
Rgds,
Norm
Rgds,
Norm
greetingz,
greetingz,
Rgds,
Norm
Your front fog light and rear fog light should have independent icons that light up at night. When you pull out to position one, the green front fog lamp light illuminates and when you pull out to position two, the red rear fog lamp light illuminates and lets you know that that is on. As for clockwise and counterclockwise adjustments of the knob, these do not change illumination.
I hope this demystifies any confusion, and I hope that your panel is working properly.
Note: I originally thought one rear foglight was burned out but my Owner's Manual told me that there's only one bulb on the driver's side. I do think that's strange to only have it on one side. I would think people behind me would think I have a bulb burned out also.
Rgds,
Norm
The single rear fog light is the EURO standard and I think its just your break light initiated on the one side so if you had both on then people behind you wouldn't have any break warning>>>>>
Rgds,
Norm
U R correct. Single light is still the EURO standard though...
greetingz,
greetingz,
Rgds,
Norm
