Hello from new zealand
Old Jan 12, 2005 | 10:15 PM
kiwi's Avatar
c32 amg
Hello i am from New Zealand. Here is a pic of my car don't know if there is any body esle in auckland with a c32.
Attached Thumbnails Hello from new zealand-kiwi-c32-f.jpg   Hello from new zealand-kiwi-c32-side.jpg
Old Jan 12, 2005 | 10:25 PM
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
Could you please share your observations of the Coriolis force? Pictures would be cool.
Old Jan 12, 2005 | 10:38 PM
EKaru's Avatar
Porsche
Welcome aboard...! Nice looking car
Old Jan 12, 2005 | 10:56 PM
hantzis's Avatar
2004 C32 AMG
NICE, welcome! Who makes those rims?
Old Jan 12, 2005 | 11:02 PM
miroj's Avatar
This is a myth. The coriolis effect is only 0.1% of the force applied to draining water. The main effect is that of conservation of momentum.
Old Jan 12, 2005 | 11:08 PM
kiwi's Avatar
c32 amg
They are from tsw and they are not good. I have already bent one in the front already reckon they are too soft.
Old Jan 12, 2005 | 11:13 PM
rrf's Avatar
rrf
Thumbs up Welcome
New Zealand!
Welcome!
Old Jan 12, 2005 | 11:19 PM
EKaru's Avatar
Porsche
Coriolis is urban legends my friend:
Claim: * Thanks to the Coriolis effect, toilets flush clockwise in the northern hemisphere and counterclockwise in the southern.
Status: * False.
Example: * [Collected via e-mail, 2003]
Water in a pan, sink, or toilet rotates counter clockwise in the northern hemisphere and clockwise in the southern hemisphere. This is due to the Coriolis Effect, which is caused by the rotation of the Earth.
Origins: * Because the Earth is a globe spinning on an invisible axis, a point at its equator will make a circuit of 25,000 miles in the space of a day, but any point not on the equator will make a shorter round trip; the closer that point is to either of the poles, the shorter its trip will be. Put another way, a pencil at the equator travels 1,030 miles an hour, whereas another at Sarasota, Florida, moves at 930 miles per hour, and one at the North pole doesn't move at all.
This apparent difference in speed results in the Coriolis force, an effect that imparts a twist to largish events happening away from the equator. Best known is its effect on air masses: as they move away from the equator, their speed (which matches that of where they started from) appears to be faster than that of the surface over which they are traveling. This sets them turning in a clockwise twist in the northern hemisphere and a counterclockwise twist in the southern. (Before you complain we have that backwards, please click here.) Likewise, a cannonball fired due north will veer a teeny bit to the east, and one fired to the south will deflect ever so slightly to the west, something a skilled gunner would make an adjustment for.
The twisting effect of the Coriolis force is real and does influence certain large things like the movement of air masses, but the effect is so small that it plays no role in determining the direction in which water rotates as it exits from a draining sink or toilet. The Coriolis effect produces a measurable effect over huge distances and long periods of time, neither of which applies to your bathroom. Toilets and sinks drain in the directions they do because of the way water is directed into them or pulled from them. If water enters in a swirling motion (as it does when a toilet is flushed, for example), the water will exit in that same swirling pattern; as well, most basins have irregular surfaces and are not perfectly level, factors which influence the direction in which water spirals down their drains. The configuration of taps and drains is responsible for the direction of spin given to water draining from sinks and bathtubs to a degree that overwhelms the slight influence of the Coriolis force.
The belief that the Coriolis force influences the direction in which water drains from plumbing fixtures is widespread and has been repeated as fact in a number of venues, including popular television shows (such as world traveler Michael Palin's Pole to Pole) and even in textbooks. We can only speculate on why people are so enamored of this snippet of misinformation, guessing that it has something to do with the desire to find some of the mysteries of science in the realm of the everyday.
Barbara "as the whirl cisterns" Mikkelson
