Are koni Adjustables prone to leak?
I spent the money on the Koni adj and my Bilstein SP's are only 8 months old(presently on the car).I just want the rear to stop hitting the rear tires on hard launches so I chose these(Koni's) for adjustability.
Present setup: Bilstein Sp + eibach springs(prokit).
Setup sitting in House:Koni adj + H&R's
Put the Koni on, you will be glad you did...
The front left adjustable shock might be slightly obstructed by the throttle linkage. People recommend moving the linkage a little (I just used pliers to turn it instead of moving the linkage to allow passage for the supplied knob).
From the back you will have to take them off the car to adjust unless you send your rear one to be converted to externally adjustable.. (But last time I check it going to cost me around $97 each to do the conversion)
Regardz,
Regardz,
I'm almost ready to sell these Koni's.
I'm almost ready to sell these Koni's.Since you have much more power than any W202 AMG from the factory.
But I have a feeling you'd be better off with H&R spring and Koni, since H&R is definitely stiffer than Eibach and you could also adjust koni to its firmest setting on the back to test.
In any case, you should not have any rubbing issue if the rear setup correctly.
BTW what kind of tire sizing are you running ? I Am running 255/35/18 and have no rubbing problem then again my car have less thrust than your :p
Regardz,
J Irwan
Regardz,
J Irwan
I'm almost ready to sell these Koni's.I have 255/35/18 on my W202 & don't have any rubbing issues
could you check which part of the car does the tire rub with. ?
If it rub with the bumper piece, nothing a lilttle dremel can't solve.
But if rub with the fender lip and you might need some minor rolling on the specific spot/area
Regardz,
Regardz,
Just FYI, even bilstein leaks too
I had E36 325 before at it least once, and my cousin E36 they leak twice.
The koni on my C36 has been on the car for 2.5 years and it doesn'e leak so far.
Anything can go bad, just depend on your luck.
Regardz,
all components on the suspension are separate. it should be easier to remove than a "coil-over" setup like the w203 macpherson struts.
