C43 leaking oil.. likely spot?
who did you get that e-mail from?
The only leaks that we see on the M112/113 engines is at a small cover on the front cover near the oil filter housing.
__________________
MERCEDES BENZ MASTER GUILD TECHNICIAN (6 TIMES)
ASE MASTER TECHNICIAN
27 YEARS DEALER M.B. Shopforeman
MB technical information Specialist (7 years)
190E 2.3 16V ITS SCCA racecar (sold)
1986 190e 2.3 16V 2.5 (sold)
I thought I had the common oil cooler leak, I cleaned the area below the oil cooler, replaced the 2 oil cooler seals, fired her up and realized the oil was coming from the plate/ cover below the oil cooler. Does anyone know what this plate is called? Better yet does anyone have a source for that replacement seal?
Did you happen to find out the name of that plate and /or part number, I think/know I am having the same leak on My c280
Lorne
