C43 leaking oil.. likely spot?
Old Oct 28, 2005 | 01:53 PM
keynote22's Avatar
Seems to be in the front towards the top of the motor. At least I can see oil on the ac lines dripping down. I recently had the HB recall done... could that be an issue? 85k and the leak is pretty bad. I cant see anything from the top. Any idea where the culprit is or where i might start looking? Doesnt seem to be a valve cover. Thanks
Old Oct 28, 2005 | 02:04 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Have you removed the air cleaner/air filter housing yet to verify location? Give us more info....
Old Oct 28, 2005 | 02:14 PM
keynote22's Avatar
Can do. I just didnt want to start ripping stuff off if there was no way I wanted to tackle the job I might find. I was kinda hoping some would say, "oh ya the kunooter valve goes bad and it cost $5 to fix" I guess I'll get the tools out and try to pin it down. Thanks
Old Oct 28, 2005 | 02:18 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
If possible , pics would help........again , if possible.
Old Oct 28, 2005 | 04:18 PM
StapleGun's Avatar
For starters..you don't really need any tools to simply remove the air cleaner housing. But get 'er done and we're here to help...as best we can!
Old Oct 28, 2005 | 05:01 PM
keynote22's Avatar
Heh, thanks for the heads up on the no tools. I just got this and havnt poked around under the hood too much yet. I hate taking stuff apart with out a shop manual.. something always breaks. lol
I'll play with it tomorrow and see where it gets me. I'll keep ya posted
Old Oct 28, 2005 | 05:04 PM
keynote22's Avatar
I just got this email I thought I'd pass on. I'll verify it tomorrow.
The only leaks that we see on the M112/113 engines is at a small cover on the front cover near the oil filter housing.
__________________
MERCEDES BENZ MASTER GUILD TECHNICIAN (6 TIMES)
ASE MASTER TECHNICIAN
27 YEARS DEALER M.B. Shopforeman
MB technical information Specialist (7 years)
190E 2.3 16V ITS SCCA racecar (sold)
1986 190e 2.3 16V 2.5 (sold)
Old Oct 30, 2005 | 04:50 AM
linuxfoo's Avatar
hey keynote,
most likely your oil leak is from the oil cooler that mates to the oil filter housing. there are two o-rings between these two parts and they get hard and crack over time. the oil will leak from the back so from the front its not too apparent and most people miss this and think that the leak is coming from else where such as the power steering pump lower in the engine. the o-rings are somewhat expensive like $15-25 for one. take a real good look behind the cooler and see if you see any signs of oil. my bet is that your oil is leaking form there. if your really mechanically inclined, you can probably do this fix yourself, but it is very time consuming. good luck
Old Oct 31, 2005 | 07:23 PM
keynote22's Avatar
yup, that was it. Thanks.
Old Nov 1, 2005 | 12:05 AM
linuxfoo's Avatar
always glad to be of help.
Old Nov 1, 2005 | 08:44 AM
StapleGun's Avatar
Thanks for the "pointer" Linux! No probs yet in that area....
Old Nov 1, 2005 | 08:45 AM
StapleGun's Avatar
Hey keynote..how much did you locate the parts (o-rings) pricewise?
Old Nov 1, 2005 | 02:08 PM
linuxfoo's Avatar
hey staple, i think its dealer item only part, when i bought mines, no one else had the part.
Old Nov 1, 2005 | 02:14 PM
StapleGun's Avatar
Thanks Linux...always appreciate the info!
Old Nov 3, 2005 | 01:18 PM
midasmike's Avatar
'93 300CE
c43 oil leak
just had the same leak on my '98. orings were the problem. cost about $32 fot parts.
Old Nov 7, 2005 | 06:06 PM
keynote22's Avatar
it was just loose. i put a wrench on it and good to go so far.
Old Nov 7, 2005 | 06:44 PM
StapleGun's Avatar
Just send linux a check for $25
Old Nov 8, 2005 | 07:03 PM
linuxfoo's Avatar
keynote, glad that you fixed it. it always good to hear back of the results.
staple, hahaha thanks for the thought!!! always glad to be of help to all. i already went through some of the problems that you guys may see, so it only serves right to help other fellow AMG'r
Old Mar 11, 2008 | 01:39 AM
sgort2's Avatar
2005 SL 500
keynote22,
who did you get that e-mail from?
__________________
I thought I had the common oil cooler leak, I cleaned the area below the oil cooler, replaced the 2 oil cooler seals, fired her up and realized the oil was coming from the plate/ cover below the oil cooler. Does anyone know what this plate is called? Better yet does anyone have a source for that replacement seal?
Old Mar 11, 2008 | 01:45 AM
sgort2's Avatar
2005 SL 500
pelicanparts.com has the oval seal, part # 112 184 02 61, for $17, and the circular seal, part # 112 184 03 61, for $16.50
Old Mar 11, 2008 | 08:40 AM
NitrogenBalance's Avatar
none
Wow old thread, I posted a DIY on here with a ton of pics and everything. If anyone plans on tackling it themselves...I'm sure the thread is deep within the powers of the search though.
Old Apr 23, 2008 | 05:58 PM
RAFFIE55's Avatar
Used to drive E55
Originally Posted by sgort2
keynote22,
__________________
sgort2,
I think I got a similar oil leak. My mechanic says it's the oil filter housing. What he means is probably either the oil cooler o rings or the plate/cover you are talking about. Did you ever find the part number and fix the leak? Is it hard to do or do I have to pay him $200.00 to fix it.
Old Apr 23, 2008 | 08:11 PM
AMGC43C55's Avatar
99C43 05C55 06slk55
oil leaks from the front can be the oil presser port ( thay have a updated cover and seal), oil filter houseing seal, and oil cooler, all the parts are about $30. it will be safe to do all the seals thay get old and the heat from the engine does not help. it is easy to do will take about 1 1/2 hr
Old Apr 23, 2008 | 08:54 PM
MBHustla858's Avatar
what is the "hb" recall?
Old Apr 23, 2008 | 09:18 PM
CFLPEEK's Avatar
96 c36
harmonic balancer
