Kleemann LSD
Old Dec 21, 2005 | 03:20 PM
FLYNAVY's Avatar
BMW and Mercedes
Kleemann LSD
Over on the E55 forum, there was a discussion about aftermarket LSD's, and was wondering if the Kleemann diff would work for our cars too? (or if they make something similar for the 202). Anyone done this mod?
Old Dec 21, 2005 | 05:47 PM
2QUIK4U's Avatar
Yes, Kleemann makes it for your car, cost is 2300.
Currently, Evosport is working something out with Quaife (best manufacturer of LSDs) to manufacture an LSD for the C55/C32. It should fit the C43 as well. Call Vadim at evosport for more info. They should be ready for delivery within the next couple of months.
Old Dec 21, 2005 | 09:09 PM
FLYNAVY's Avatar
BMW and Mercedes
awesome....may have to look into the Quaife....just out of curiousity, why is theirs the preffered model? (vs Kleemann)
Old Dec 21, 2005 | 09:27 PM
2QUIK4U's Avatar
I wouldn't necessarily say that Quaife's is preferred, given that it does not exist yet for our cars. However, they specialize in making differentials and they have been doing it successfully for many years. They also have a patented ATB technology (http://www.quaifeamerica.com/) which apparenlty works very well. I am sure the Kleemann unit is great, I have only heard/read positive things about it. However, Kleemann offers an LSD along with many other products. Whereas Quiafe is specifically focused on differentials and transmissions.
Additionally, the Quaife unit should be quite a bit cheaper than the Kleemann LSD. Current estimates are around 1200-1400. Should be available around January. See the following thread for more info: https://mbworld.org/forums/c32-amg-c55-amg-w203/110488-quaife-lsd-c55.html
As a note, you would be surprised how many questions can be answered by using the search function.
Old Dec 21, 2005 | 10:23 PM
FLYNAVY's Avatar
BMW and Mercedes
thanks for the info/link and my bad about not searching first
Old Dec 22, 2005 | 01:53 PM
speedybenz's Avatar
AMG C43, 1999
I have the Kleemann LSD in my C43, 1999. It works great and you don't feel it kick in or any of that. It just gives you much more traction. Wet weather driving is a ton nicer with the LSD.
Jeff
Old Dec 25, 2005 | 03:49 PM
FLYNAVY's Avatar
BMW and Mercedes
so what ratio is the Kleeman unit? I guess it wouldn't hurt to get a little extra "off-the line" performance if I'm gonna be spending the $$ anyways.
Old Jan 7, 2006 | 02:25 PM
trust068's Avatar
does my 95 C36 came with LSD standard? or it is open differential?
Old Jan 11, 2006 | 12:38 AM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
is LDS traction control?
Old Jan 11, 2006 | 12:20 PM
FLYNAVY's Avatar
BMW and Mercedes
Originally Posted by e320newbie
is LSD traction control?
not exactly, although I guess it sort of performs some of the same functions. Plenty of cars w/ traction control do not have LSD
Old Jan 11, 2006 | 02:15 PM
E43's Avatar
E43
2000 E430 Sport
An LSD is not traction control per se, but it does aid in traction. An LSD is a mechanical device in the differential that distributes power to the wheel that has the most grip. Mercedes Benz traction control is an electrical device that applies the brakes to a wheel that is slipping or losing traction. In my opinion, an LSD would give you better performance and handling.
Old Jan 11, 2006 | 10:47 PM
e320newbie's Avatar
how do i find out if my car has one?
Old Jan 11, 2006 | 11:24 PM
FLYNAVY's Avatar
BMW and Mercedes
unless someone has modded it, you don't....group buy maybe
Old Jan 12, 2006 | 12:45 AM
e320newbie's Avatar
if i get 1,,, what will she do for me? i have trac control does that matter?
Old Jan 12, 2006 | 10:44 AM
E43's Avatar
E43
2000 E430 Sport
As I mentioned earlier, the traction control applies the brakes to stop wheel spin. This is fine during normal driving situations, but it is not the fastest way around the track or down the strip. If you are a performance oriented driver, you probably want the LSD because it will improve your times down the strip by .1 or .2 seconds, and it should also provide you with better control and traction around corners.
