80mph @3000rpm?
But when I stop and drive I can see and feel that it shifts 5 gears. I will sleep better tonight if this 80mph at 3000rpm is normal. Cause when I hit the pedal little more, it still flies without downshifting.
Thank you
So according to my car your fine, if not we have the same problem. LOL
However, not too long ago I had my car up to 140mph and it didn't seem to be screaming or maxxed out. It actually achieved the speed pretty easy. So maybe 5th is a big ol' gear as 140mph is almost twice that of 80mph and the rpms didn't climb to much to achieve that speed. I've heard they will hit 168 with the V max limiter shut off, ECU mods can do this.
I think your ok, on a side note, my 99' W202 kompressor was right at 3000rpm while cruising at 80mph.
P.S.
I'm having the kleemann ECU done at some point before spring(been sayin this all winter) and that should put my limiter around 168mph. Plan on getting a video shot of a high speed run around 160 if I can get enough room.
Thank you
thank you
Short answer: yes.
Long answer:
Engine RPM at a given speed is a function of gearing, and other than slight changes in wheel diameter, I can't think of any popular modifications that affect this. Intake, exhaust, new plug wires, braking hardware, even forced induction or a limited slip differential--none of these would affect the RPM an engine turns at 80mph. Therefore, even if you hear from someone who has modified their car, there is a good chance the comparison is still valid, as long as it is in fact an identical model.
Aside from a false tachometer reading, here are two likely ways in which your car would be turning a higher than normal RPM at 80mph: the diameter of the tires is smaller than it should be, or the car's transmission is not successfully shifting into its highest gear. I'm assuming that you would be able to verify the correct rolling diameter based on tire specs, so here is an idea regarding the second scenario.
A simple experiment. (1) Drive 80 mph with the transmission in "D". Note engine rpm. (2) Drive 80 mph with the transmission in "4". Note engine rpm. (3) If engine RPM was lower in step 1 than in step 2, your car is probably succesfully shifting into 5th gear, and you are probably okay.
Enjoy the ride.
Regards,
e harmon
Thank you kindly!
Enjoy the ride.
Regards,
e harmon
[QUOTE=So maybe 5th is a big ol' gear as 140mph is almost twice that of 80mph and the rpms didn't climb to much to achieve that speed. [/QUOTE]
