upgrade time
Old Jun 5, 2006 | 07:43 AM
Teck's Avatar
C 320 CDI 4M W204 / C43 AMG (W202) / C 220 CDI T (S203) / ZX-10R Ninja
upgrade time
Well as some of you guys know my drivers license is gone for 3 month. Half time is over and I want to do some work on my car. I thought about some new shocks and a brake upgrade. I'm going to the Nürnbugring in August when my license is back so my car has to be in perfect racing condition. What do you guys recommend?
Old Jun 5, 2006 | 02:30 PM
Vardar's Avatar
1999 C43
nothing, it's a nice ride.
Old Jun 5, 2006 | 02:50 PM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
get the camber setup properly for a track run... hopefully, enough negative camber so that maintain proper contact patch. bump up the tire pressure to maybe 40ish, esp if u are rolling on them in hard corners. if the latter is the case, check the alignment or get stiffer sidewalled tires. i suspect u still have the brabus springs on stock shocks.. see how it rides on that setup at the ring. if u don't like it, then get something else for the next run. the v8 should be a blast to get thru the ring.
Old Jun 5, 2006 | 03:00 PM
Teck's Avatar
Great info thanks I will def bump more pressure into the tyre! The negative chamber is also very important plus I will take the OEM 17'' wheels for the track and not the 18'' because of damage!
What dou you think about the brakes and some minor suspention work?
Old Jun 5, 2006 | 09:27 PM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
teck my brotha! sounds fun!
Old Jun 6, 2006 | 02:34 AM
Ashkan's C43's Avatar
c43
bilstein sport shocks, eibach sways, unless you can get any of jeff's parts get those, lpd lower control arm bushings, jeff's camber arms for sure
Old Jun 6, 2006 | 02:35 AM
c43
get some evosport pullies....
Old Jun 6, 2006 | 06:22 AM
Teck's Avatar
Sway's yes of course where can I get the best offer?
Not sure about pullies it may be that the engine overheats!
Teck's Avatar
Yo yo man whaz up
Old Jun 6, 2006 | 02:11 PM
steve s's Avatar
brakes? if u have the 4 piston calipers (which i don't ), then get some better fade resistant pads.. if u really wanted, some slotted rotors might work well.. drilled ones tends to crack under enormous stress.
Old Jun 6, 2006 | 03:57 PM
mthomas141's Avatar
2005 S4
why is ur license gone?
Old Jun 7, 2006 | 02:09 AM
Teck's Avatar
Got to check that today thanks steve.
mthomas141: Speeding 155 mph in a 75 mph zone (Switzerland)
Old Jun 7, 2006 | 05:11 AM
steve s's Avatar
haha..don't do that anymore.. now do it legally at the ring!
Old Jun 7, 2006 | 06:12 AM
Teck's Avatar
lol that's why I've orderet the new V1
Old Jun 7, 2006 | 10:00 AM
Vardar's Avatar
1999 C43
If I am not wrong, he had a speeding ticket, and $10k fine with that frankenstein vehicle. I might be wrong...
Old Jun 7, 2006 | 10:04 AM
Teck's Avatar
WTF??? Frankenstein vehicle??? If you don't like my car you don't have to post such comments about my car because I and some ozher members like it! Thank you!
