Best Grill for C43
ForMyMercedes:
Avantgarde Grill Insert
http://www.formymercedes.com/mb_resu...ategory=Grills
ForMyMercedes:
Elegance Grill Insert
Bekkers:
Avantgarde Grille (is this the same Schatz as the one at "ForMyMercedes")
http://www.bekkers.com/Merchant2/mer...illaccessories
I'm leaning toward the "Elegance Grill" from ForMyMercedes because I love the way the center large star looks in the grill on CLK's, SL's, etc. but if this part's quality isn't great, I'm afraid it will look very cheap.
It's really imppossible to judge the real quality of a piece like these online, so I'm especially interested in any feedback you all have from first hand encounters.
Thanks in advance....
All in all, the quality was pretty good for the price. I had to remove a bit of plastic from where the 2 top inside clips fit to get it to work, though.
It had the upper left blocked out like the stock grill, but did not have a place to re-attach the removable factory piece that blocks out the upper right section. Do you guys typically just leave this area un-blocked?
Right behind there are the electrical connections for the fans, so I assume that part was meant to help keep water off of those...
Anyone had any problems as a result of this?
ForMyMercedes:
ForMyMercedes:
Bekkers:
i think its good to open it, cause its directly front to the Right air inlet tube, isn’t.....
??!!Attachment 255110
Attachment 255111
*Prefer to go with a grill like this:
Attachment 255115
ZAYED,,
It's indeed to block water and large debris from the air inlet. c43 has two intake tubes, but every other model only has an intake on the left side (facing the grill) which is why there is only a flap on that side
