Brakes!!!
Old Sep 28, 2006 | 11:24 AM
Jon R's Avatar
1999 C43
Brakes!!!
Well, after about 50k miles on my 1999 C43, I have been told that my front rotors are wearing too thin and will need to be replaced. I told them to put a hold on it until I could do some research on a good price for some ATEs.
I would really appreciate it if you all could help me. I think I remember hearing that the Power Slot ATEs (with the elliptical grooves) were a direct plug-and-play replacement. Is there anything true to this? If so, where can I order some?
If not, I will settle for a good price on an OEM replacement. As for you guys, where would you go to order replacement OEM brakes like these?
Thank you in advance!
PS. Gotta get pads too. Any suggestions would help.
Old Sep 28, 2006 | 03:11 PM
MBHustla858's Avatar
oem is your only choice there bud, the stock rotors are made by SHW of germany, something like 270 a pop. your best bet is to suck a dick at the local benz dealer for a discount
Old Sep 28, 2006 | 11:41 PM
85Cosworth's Avatar
95 Bronco w/351 V8 & 2003 Mustang MACH 1
I got front rotors (cross drilled) and pads for my 97 C36 for $325 from my local mechanic. Installed them myself. If the rotors are rusted on like mine were, get some penetrating lube and a big hammer. That is how I had to get mine off.
Old Sep 29, 2006 | 01:11 AM
c36 is alot more different than a c43.
Old Sep 29, 2006 | 03:07 AM
85Cosworth's Avatar
the front discs are only .5 inch bigger and they both use 4-pot calipers. It can't be that much different.
Old Sep 29, 2006 | 09:56 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Really? I have cross-drilled and slotted on my C43.They are made by Disc Italia. Check this thread : https://mbworld.org/forums/c36-amg-c43-amg-w202/151413-c43-powdercoated-calipers.html.
Old Sep 29, 2006 | 05:45 PM
ivancook's Avatar
I just purchased a used '99 and all four of my discs are quite used.
I'm getting quotes in the Austin area for replacing all 4, with new pads (including sensors) and a flush of the brake fluid in the $1300 - $1500 ballpark.
Best price I've seen online for the rotors is around $479 for the pair on ebay. The seller is in WA, and the auction ended recently with no buyer. He also said that he had 4 pairs.
Anyone interesed could get in touch searching the recently completed...
Best of luck.
