Crank Position Sensor location?
Old Jul 1, 2007 | 11:34 PM
sgort2's Avatar
2005 SL 500
Where is the crank position sensor located? Does anyone have a pic?
Old Jul 2, 2007 | 12:22 AM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
I think there's a pic in the W210 forum. Same place. Use the search and I'm sure you'll find it. I seem to recall someone here - Nitro or Staplegun maybe? - had posted pics too.
In a nutshell it's at the top of the bell housing in a semi-hard-to-reach location. I picked up a flex extension to help with the r&r. In fact, whoever it was (sorry for not recalling exactly) that posted in here had listed tools as well. Search and ye shall find.
Old Jul 2, 2007 | 07:21 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
It has been posted many times - it is located on the driver's side bell housing aka the flywheel housing. If you shine a high powered flashlight directly aft of the left cylinder bank you'll see the CPS w/plug - you'll need a small e-torx, 1/4" ratchet with universals and a little patience.
Old Jul 2, 2007 | 03:13 PM
sgort2's Avatar
2005 SL 500
Thanks for the help, guys. Have you guys heard of these working intermittently? On 3 separate occasions I tried to start the car and the starter cranks but the engine won't turn over, 1 time it stalled while idling. When I wasn't able to start the car all I had to do was wait about an hour and it would start, it never started when I immediately re-tried. I replaced the fuel filter, removed the fuel pump and applied direct voltage to the pump and the pump worked. Based on the threads I've read my last guess is the crank position sensor? Any additional suggestions would be greatly appreciated.
Old Jul 2, 2007 | 04:05 PM
StapleGun's Avatar
Apparently this is a problem that manifests itself when the car is warm. Car will start once cooled off but problem will come back - who knows when though.
Old Jul 2, 2007 | 05:39 PM
SDR's Avatar
SDR
Symptoms described are exactly what happens with a failing CPS.
Old Jul 3, 2007 | 04:35 AM
benzmodz's Avatar
W203 slightly modified
Usually the CPS is on the topside near the back of the engine, on the bell housing of the transmission.
Old Jul 18, 2007 | 11:28 PM
sgort2's Avatar
2005 SL 500
Thanks guys, that did the trick, bimmerparts.com had one for $78.38, they're listed in their catalog as a reference sensor. I included a pic of the location of the sensor.
