What are your real-world 0-60 times for your C36?
Old Sep 22, 2007 | 05:24 AM
BongC36's Avatar
95 C36 AMG, 02 SLK320, 06 Accord V6, 08 BMW 335i
My 1995 C36, even when it was new, cannot break the 7.0 second mark going from stand-still to 100 kph (0-62 mph). I saw in a scanned article from Car & Driver and Road and Track in another forum that the 0-60 time that they got is 6.0 seconds. The figure quoted in my AMG Owner's manual is 6.7 seconds.
I tried many times to accurately determine my 0-100 performance using my phone's stopwatch but the best I could do was 7.2 secs when the engine was cold and around 7.8 when warm. My car does not have ASR and is bone-stock. My fuel is 96 RON but I use additives to increase it approx 98 RON as required by AMG.
I was wondering if my fellow C36 owners have tried to record their own 0-100 times. Does anyone know how these magazines staff conduct their tests? I start FROM IDLE and just push the pedal down at the same time as I press the START button on my stopwatch. Maybe they brake-torque their samples? i.e. rev the engine while holding the car with the brakes then let go at START.
My car hits the 250 kph speed limiter quite easily so I don't think I'm down on power but even my SLK 320 can beat the C36 in a stoplight shootout.
Old Sep 22, 2007 | 12:59 PM
Militant-Grunt's Avatar
95 Audi urS6 Quattro
What is the mileage on the car? Chances are it needs a tune up.
Old Sep 22, 2007 | 01:08 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Originally Posted by BongC36
Does anyone know how these magazines staff conduct their tests? I start FROM IDLE and just push the pedal down at the same time as I press the START button on my stopwatch. Maybe they brake-torque their samples? i.e. rev the engine while holding the car with the brakes then let go at START...
Try brake-torquing. You should see a difference with your car.
Old Sep 22, 2007 | 08:43 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
On my beltimer I get mid 5 sec 0-60 and low 14sec @99mph in cool weather. Its got to be cool out and not heat soaked. Heat makes the car sluggish in the lowend. Its within .1sec from real time. My c36 is stock and has denso iridium plugs. If you have trouble with a slk 320 your car is not running right. I have no problems staying right with sl 500s.
Old Sep 23, 2007 | 12:36 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
heat sucks. ran only around 15 at sears pt on those wed night drags, and roughly 96 mph. wayy too hot there, close to 100. and parking on that concrete where the internal temp read 100+ didn't help.
Old Sep 23, 2007 | 01:16 AM
BongC36's Avatar
My car's mileage is 54500 kms and is in top tune except for a recent mild flat spot at 3200-3600. I have attended to the usual suspects, i.e. MAS, wiring harness, coil pack etc etc. My measured times of 7.2-7.8 secs was when there was no hesitation yet
Do the magazines brake-torque their test mules to get those amazing numbers?
Jon, mid-5's is amazing! Do you brake-torque it or just launch it off idle? When I sit in traffic my temps rise to more than 100C and the acceleration really goes away...
Old Sep 23, 2007 | 07:42 PM
I take off from idle with ASR off. If you have a flat spot in any part of the rpms you have a problem. It should be smooth through out the rpms. Did you replace the wiring harness yet?
Old Sep 24, 2007 | 03:05 AM
BongC36's Avatar
Wiring harness, MAF sensor, coilpacks, plugs, fuel filter and all the usual suspects had been replaced already. When I was doing those 0-100 runs a few years ago there was no hesitation yet. This 3200-3600 rpm flat spot is a recent malady.
BTW sorry but what is a Beltimer? I timed my runs manually, trying to sync my pedal push with the start button on my phone's stopwatch function.
Old Sep 25, 2007 | 07:47 PM
Its a plug and play device which tells you the break down 0-30,0-40,..1/4 times and spd. Its pretty accurate to real time.
Old Sep 25, 2007 | 08:36 PM
ob1kenobi's Avatar
moon buggy
Bong,
Do you have traction control? If you do, have you tried turning it off
when doing your 0-60 run? (or in your case 0-100)
The reason I asked is because the flat spot you mentioned seems to be
inherently the same as what happens to my E55 when I try to pick up
speed rather quickly (flooring it from a dig). My solution is to simply
turn off the ESP and it goes away.
Old Sep 26, 2007 | 03:06 AM
steve s's Avatar
i don't think the 95 came with esp. if anything, just a simple asr which utilizes the brake system (right? i think... )
Old Sep 26, 2007 | 06:29 AM
BongC36's Avatar
No, my car didn't even come with an ASR. This flat spot is a fairly recent incarnation of the devils that seems to bedevil MB's.
