When SRS light is on.......
If the SRS light is on, does that mean airbags will not deploy?
Since I bought my car, the light was always on, I learned to ignore it....
I thought maybe there is someone here has the same problem..
Thank you
Thank you
..Last edited by Vardar; Oct 2, 2007 at 07:27 PM.
I've been driving this vehicle with those lights on for more than 2 years, you might open the door to a cheap solution as oppose to the sensor replacement which costs about $750+
Thank you.
Thank you.
After paying this amount I did some research on this and it doesnt seem to be that difficult to replace, next time it will only cost me about 120 and I'll do it myself.
If your air bag light is lit on the dash and on the center console, most likely it is a problem with you passenger sensor in the seat or it's connection under the seat.
Thank you
I checked the cables and plugs at the bottom of the seat, and could not find the problem. I believe it is the sensor. Do you remember the part number, or where you purchased it? I believe once I buy it, i can handle the rest.
Thank you in advance for your help.
I would like to get it fixed as practical and cheap as possible. I hope you would understand.
(sorry for misspelling)
i was only explaining how i would react to the same problem, were it my car. good luck with your children and your car.
some people would consider no air bags and non operating seatbelt tensioners a threat to any passenger in your car.
they might even consider it a threat to the health and well being of your children, if they were to ride in your car with the above mentioned safety problems.
Have a great one.
you've been driving your car with 2 serious safety issues for 2 years and haven't spent the money to repair stated issues, apparently not being able to justify the cost.
then in that next breath you try to justify this error in judgement by stating you don't want to jeopardize your childerns health and well being. i'd say they've been at risk for 2 years and will continue to be so until you repair the stated problems.
I looked it up in the forum here, someone said it was only the $100 seat buckle...
Any ideas?
Thank you
Do you have any idea of how to retrieve the part number?
