ET rim questions, please answer.
Old Nov 1, 2007 | 08:53 AM
cfourthree's Avatar
98 c43
Okay so I have owned my car now for 5 months and have had 3 sets of wheels and considering the forth. Here is what I have learned. Besides stock is best.
18x9 and 18x10 ET44 fit all the way around. 9's on that high of an offset rub the control arm slightly. 225x40 front and 245x35 rear
19x8.5 and 9.5 ET35 fit all around but with 235x40x19 and 265x35x19 the tires rub the fenders.
Now the question is I plan on running 18x8.5 and 9.5 ET 25 in front and ET28 in rear. Now I know the rears will fit and be fine. The question is will the front rub. I know the fronts are 10mm lower ET in front that stock. So any advise will be great. The rims btw are OEM CLS AMG wheels. Thanks.
Old Nov 1, 2007 | 07:20 PM
Lensolo's Avatar
99 C43 AMG
I think you'll be fine as long as your car isn't lowered. Both of those offsets are fairly aggressive.
Old Nov 1, 2007 | 08:51 PM
cfourthree's Avatar
98 c43
my car is dropped, I am thinking the front is going to rub.
Old Nov 2, 2007 | 12:04 AM
Lensolo's Avatar
99 C43 AMG
Without a doubt. My car is pretty low too and i'm on 18x8 +31 AND rubbing.
Old Nov 2, 2007 | 08:01 AM
cfourthree's Avatar
98 c43
lensolo. Thanks for the replies. What size tires are you using up front? I was debating on stretching a 215x40x18 on the fronts to try to limit the rubbing.
Old Nov 3, 2007 | 10:53 AM
4.5_sport's Avatar
1979 VW Rabbit, 1994 E320T
I'm currently running Fikse FM-10's with a ET28 in the front and rub ever so slightly on the fender with 225/40-18
Old Nov 3, 2007 | 03:17 PM
cfourthree's Avatar
98 c43
4.5 thank you very much, That is what I needed to hear!
Old Nov 3, 2007 | 05:30 PM
Lensolo's Avatar
99 C43 AMG
i'm also on 225 40 18.
Old Nov 3, 2007 | 07:21 PM
x15jq's Avatar
Well, the reason your tires rubbed with the 19's is cuz those tires are s class sizes. You need a 235/35/19 front and 265 30 19 rear. Then it shouldnt rub. I think youll be fine with the new setup its better to have that rim away from the control arm, just roll the fenders if you need to and run a narrower tire to get by.
Old Nov 8, 2007 | 08:43 AM
cfourthree's Avatar
98 c43
So to answer my own question I just got the wheels and put them on. The ET is actually perfect of these cars as it brings the wheels right to the lip of the fender. Again I am running cls amg wheels 18x8.5 and 9.5 ET25 F and ET29 R.
Old Nov 9, 2007 | 10:56 AM
Lensolo's Avatar
99 C43 AMG
Can't wait to see the pics!!!! It probably looks awesome!
Old Nov 11, 2007 | 09:42 PM
4.5_sport's Avatar
HAve you got any pics, yet?
Old Nov 12, 2007 | 08:57 AM
cfourthree's Avatar
98 c43
I am going to take some today just have to get 1 front tire mounted today and them get the balanced. Should have the pics up later today. I like them alot, but really think I want to redo my lorinser rsk5s and put them back on.
Old Nov 12, 2007 | 09:44 PM
cfourthree's Avatar
98 c43
Old Nov 13, 2007 | 11:48 PM
Lensolo's Avatar
99 C43 AMG
That looks really good!! I like it. How's the rubbing?
Old Nov 14, 2007 | 03:05 AM
4.5_sport's Avatar
That is a nice look....
Old Nov 14, 2007 | 08:28 AM
cfourthree's Avatar
98 c43
thanks guys. The rubbing is not bad actually. It rubbed alot harder with the 19's. With these it only rubs in the front light on a hard dip in the road. Would be perfect with a 215x40x18 in front.
