Acceleration Lag???
1998 C43
Acceleration Lag???
Sometimes after hard acceleration, my car's acceleration seems to lag.
In other words, when I hit the gas, nothing will happen for a second or two.
It's similar to when you are driving a stick, and your are in too high of a gear.
Once I shut the car off, it seems to reset itself, and everything is fine.
But I can't always do this (ie if I am on the highway).
Any suggestions?
Any suggestions?
clean
your MAF,symptom of dirty or failing maf,before it throws a code.Fuel mileage down a bit also?
Crc brand maf cleaner only.
http://germanstar.net/MAF.htm
new insert only 129 bucks at above.
good luck
good luck
I hope it helps him,seems like the symptoms he posted.You guys with other suggestions may have another angle of attach.
good luck
good luck
over priced, get the one from the audi dealer for 67 dollars and plug it in.
I replaced my MAF with the germanstar insert last night and it is like a whole new car. I'd recommend locating a replacement.
