what's the diffrence between c43 trans and e55 trans
Old Jan 10, 2008 | 03:27 AM
KJI3jflarryfe93's Avatar
do they share the same trans? the parts number is diffrent?
do e55 owners have the same failures with their trans as the c43 owners?
can a e55 trans be connected to c43 engine if this trans is better and stronger? this concerns 98 and 99
Old Jan 10, 2008 | 06:43 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Yes it will wrk.
Old Jan 10, 2008 | 08:08 AM
Chappy's Avatar
AMG
They may work, but they are not the same part numbers.
The E55 trannsmission is more stout.
Old Jan 10, 2008 | 11:57 AM
MBHustla858's Avatar
c43 trans part # starts w/ a 202
meaning its special
Old Jan 10, 2008 | 04:54 PM
ProjectC55's Avatar
It will bolt up and wrk no problems! The part #'s maybe different but it will still bolt up and wrk. The only mod will be the shifter module.
Old Jan 10, 2008 | 05:59 PM
silence's Avatar
sounds like airplane
so when ours break we should be swapping?
-drew
Old Jan 11, 2008 | 10:13 AM
-drew
hey buddies,before i bought my car i red somwhere on the web that our cars was sharing the same transmission as the S-CLASS and SL,CL etc.etc, how come the E55 trans is better than the c43? i don't get it=?
is my trans going to get ****ed up when it reaches 100,000 miles no matter what even if i change the ATF REGULARLY? MAYBE MB buildt a bad trans deliberatly
THANKS
Old Jan 11, 2008 | 10:36 AM
silence's Avatar
the issue with ours is a more aggressive shifting module (or so i've read) that doesn't quite work right.
This may be primarily confined to the 98 and early 99s as well
Old Jan 11, 2008 | 11:55 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Probably.....it's the needle bearings that are the weak spot.
Old Jan 11, 2008 | 12:21 PM
the failiure has nothing to do w/ the programming, the bearings will fall apart taking out the whole unit
Old Jan 11, 2008 | 01:08 PM
4.5_sport's Avatar
1979 VW Rabbit, 1994 E320T
I'm there right now...
