Which Shocks To Use For COMFORT?
I believe I have moroes SENSA-TRAC shock, are these any good?
if your car is lowered and not with eibach you can likely gain a much softer/comfortable ride by switching to their springs.
-drew
I understand about the Lincoln joke, but I believe stock C Class shocks might be very soft for this preformance vehicle....
anyway, rode a different car setup with monroes and they were pretty harsh and horrible.
swap those out for the oem shocks. it seems to be ok for the c36. read somewhere that c43 shocks are stiffer, anyone know?
anyway, stock springs are usually softer than aftermarket, so if u want to keep the lowered look, u can go for the stock springs with thinner pads.
if u don't mind getting big fender/wheel gaps, try the thickest pads. that'll isolate the road even more. i know my c36 looks like it's on stilts and actually sat higher than a friend's c280 on 17" monoblocs due to the pads.
My last Lincoln - a '95 4.6L with electronic adjustable ride control had a similar ride/comfort level when it was on the 'Firm' setting, whereas when on the 'Plush' setting, it was the typical Lincoln 'isolate the road' ride, that at times I miss - especially on rough roads.
I'll soon be installing the Eibach Pro-Kit Spring Set that I recently purchased for the C43, so I'll have a new experience soon.
thas w/ the the #3 pad up front and #4 in the rear. if you are not too hot on lowering your car you may want to put #5 in the back and a #4 in the rear, our cars come w/ #2 all the way around, i just didn't want the SLAMMED BENZ
good luck.
good luck.
KYB AGX adjustable shocks.
