tranny leak
Old Feb 19, 2008 | 08:59 AM
e30t387's Avatar
s/c 99 c43 amg
tranny leak
i believe my trans is leaking i think its from that sensor on the bottom there i believe its the gasket, where can i get one or do i have to purchase the whole sensor.
Old Feb 20, 2008 | 01:28 PM
e30t387's Avatar
s/c 99 c43 amg
any one know for sure if its a common problem with these cars?
Old Feb 20, 2008 | 03:45 PM
ohlord's Avatar
722.6
trans?in your car,yup common easy fix,order the parts at autohausaz.com or the dealer and replace the parts with the new upgraded ones.
Go to one of the members on the w210 forum he is building a site called
www.everythingbenz.com
and do a search 722.6 leak
some diy tips also
ohlord
service your trans and filter while you are into it
diy on benzworld.org w210 diy section
mb spec fluid only
Old Feb 20, 2008 | 03:49 PM
e30t387's Avatar
s/c 99 c43 amg
some diy tips also
ohlord
mb spec fluid only
nice, thanks for the help, might as well change the fluid too.
Old Feb 21, 2008 | 09:53 AM
vinceC's Avatar
2014 ML350 4Matic
If the leak is coming from the forward, right corner it is probably the spacer for the electrical connector. The link is a very good tutorial.
http://www.installuniversity.com/mb/...ans_oring.html
Old Feb 21, 2008 | 02:52 PM
e30t387's Avatar
s/c 99 c43 amg
apreciate the help i had my friend put it up on the lift at the benz dealer, from what he told me its the gasket of the overhaul ( i believe thats what its called) sensor on the tranny. he replaced it havent seen any leaks yet so hopefully that was it.
Old Feb 21, 2008 | 04:57 PM
Vardar's Avatar
1999 C43
I just went to http://www.autohausaz.com/search/cat...00016@Mercedes
I can't find shocks. Aren't shocks suppose to be in Suspension area?
Old Feb 21, 2008 | 05:12 PM
ohlord's Avatar
ask
autohausaz for a quote on the shocks or call ron at http://germanstar.net/202s.htm
or in a pinch http://www.performanceproducts4benz.com/drawings.aspx
have fun
