Ride quality- stock vs H&R springs
Just bought a 99 C43 w/44k miles. The previous owner has put H&R springs on it about a year ago, and it looks good. My question is what is the difference in ride quality and drivability with the lowered suspension vs the stock springs?
My other problem is that when I went for my Massachusetts state inspection I was refused for having a "dropped" car, and was told that I need to go back to stock to pass! Unfreakingbeliveable!
I don't nessesary want to got back to stock, but I'm interesed in hearing from people who have dfriven thier cars both ways.
Thanks,
WTS
I have a 98 C43 and recently lowered my car with the H&R springs. In my opinion, there is no difference in the ride quality. Meaning it does not ride hard or stiff. I can tell the difference when I brake and accelerate b/c the body does not lunge as much as it used to.
BTW, that's bull**** about not being able to pass your car. Why dont you check out the SEMA site. They might have some info about what you can do.
Regards,
DLS
I'm gonna try another place for my inspection, I'm sure this hard *** was just lazy or something, but it's still a pain in the *** to have to deal with.
when I dropped my C43, I used the H&R sport spring set. When I was at the shop, they informed my of the spring pads that were on my car. I believe that most AMG models have the 1 pad in front and 2 in the back. My car lowered looks almost level. I am using 18 inch Mono II's. I can send you a pic if you want. If you dont want your car lowered that much, I would suggest using the Eibach spring set. I dont know much about how they ride, but I am sure they are comparable to the H&R.
Regards,
DLS
PS: It was almost a two inch drop for my car.
Don't know how many pads I have but the springs are the standard H&R ones, stated about 1.5" drop plus or minus all around. I may have to go back to stock unless I can raise her up a tad with the shims.
There are times when I hit a dip in the road and believe that I am bottoming out. I did my research pretty well, and I do not believe that I am bottoming out. Reason one, is that many cars in my area are lowered like mine if not lower. I have talked to many of the owners and a majority do not have problems. Reason two, the "rubbing" tends to come from a specific spot on my car. In fact, it ONLY sounds like it is coming from the front right. Another forum member (2Phast) said he had some front right rubbing with his C36. I believe that his set up is identical to mine. You can read about it @ www.2phast.com.
One other thing to consider is the weight of your car. Our cars are quite heavy up front, so it might be wearing the shocks extremely fast. I would suggest that see if you are rubbing on which side of your car. If it is the right, read 2phast's site and go ahead and roll the frenders. AMG has already done that for us, but rolling the fenders additionally might help out more. Also check the "front axle skid plate" I dont know what it is really called, but it is metal with a plastic covering on it. Look for scratches.
Good luck,
DLS
I checked TireRack and they got nothin!
thanks
I was considering going with the Koni Yellow adjustables, but I want to learn a little more about the Penske b4 I make a decision.
DLS
Back to the shock issue, I would go with Bilstein Sports or Koni Yellow Sports. The Koni's are about $30 cheaper per shock. You can buy Penske products at K-Mart so I don't know if I'd put those on a Mercedes, let alone and handbuilt AMG model.
P.S. Don't worry about if the ride will be stiff. I found it to be more comfortable because the car doesn't bounce or lean as much.
Thanks for the information, I will consider what you said in making my final decision.
Oh yeah, dont need to apologize for replying to this thread, we all have one common passion and many of us experience problems throughtout all MB models as well as other makes.
Thanks for you input.
Regards,
DLS
problem with koni is that u will need to take parts form ur stock shock and put it on new shocks.
also itz kinda hard to adjust since u will need ot loosen some bolts and etc
Problem??
To adjust them you have three choices soft, medium and hard, and is a piece of cake, only you do it before installation. It's not that one's installed you can adjust them at your will.
There was a comment about stock shocks wearing out quickly with H&R springs. When that happens (and it seems to have happend) what is the suggested replacement shock? I would imagine that it's not stock.
thanks
www.tirerack.com has Koni Sport Shocks @ $100 each.
I don't understand what the "I'm with stupid" comment means. Do you agree with me or do you think I'm stupid?
