HELP!!! Check engine..
Old May 19, 2008 | 01:15 PM
e30t387's Avatar
s/c 99 c43 amg
Originally Posted by Z06EATER
took the words outta my mouth you got it if you clean that sucker good you should be fine...but if yyou get a check engine light again, i would buy a new one
the one thats in there now is about 4 months old, i just cleaned it put it back together made sure harness was in right and it runs a lilte better, but last time i replaced it it ran like crap for like 10 mins then it was good and check engine when away, but im at work and i havent driven it since i cleaned it, so if its not the maf then its what ever whats his name said bout the temperature, where is that located. the code again was P0100
Old May 19, 2008 | 02:22 PM
MARTYMAR's Avatar
07' IS 350, 08' E550
Well I am currently having the same issue. My code was P0101 and the OBD ll reader listed the problem as MAF or VAF...just another name for the Air Mass Sensor depending on the vehicle make. I cleaned my sensor twice and it's better. It keeps a steady idle at around 1000 rpms as opposed to dropping below 500 as it was doing before. I did all the steps you guys listed here and currently have a new MAF on the way! ( New MAF was $177). I haven't driven the car yet since I cleaned the sensor ...will do so when i get home to see if the CEL (Check Engine Light) goes away.
Old May 19, 2008 | 04:34 PM
Z06EATER's Avatar
1997 C36AMG
HEY WAIT!
U GUYS MAKE SURE WHEN YOU SPRAY THAT SENSOR YOU BLOW ON IT AND LET IT DRY GOOD! or else u will get fowl smell and the car WILL drive like Shi* very important fellas...it could damage the car even i bet..
Old May 20, 2008 | 08:07 AM
e30t387's Avatar
s/c 99 c43 amg
ive cleaned mine before, so cleaning it did no good, i got it from german star like 4 months ago could it be bad already? what else can it be , i know you guys said the coupling, but the only coupling i have is the one after the maf i believe. its really starting to **** me off.
Old May 20, 2008 | 08:13 AM
e30t387's Avatar
s/c 99 c43 amg
i guess ill just order another one, since i think i know what the problem is, i gave the car to my older brother when i got ther new maf in from german star, asked him to put it in, idiot never put back in the filters so im assuming that its probably shot from all the **** and dust going in there.
Old May 20, 2008 | 08:46 AM
MARTYMAR's Avatar
[QUOTE=e30t387;2832563]i guess ill just order another one, since i think i know what the problem is, i gave the car to my older brother when i got ther new maf in from german star, asked him to put it in, idiot never put back in the filters so im assuming that its probably shot from all the **** and dust going in there.[/QUOTES
So you now have the new MAF installed? If so, check those filters. That's an easy fix if that's the problem otherwise, something else isn't quite right.
Old May 20, 2008 | 09:54 AM
  #32
e30t387's Avatar
s/c 99 c43 amg
[QUOTE=MARTYMAR;2832596]
no i just ordered it today, so probably will have it in a couple days , and ill make sure i put it in myself, and put the filters back as well.
Old May 20, 2008 | 11:10 PM
  #33
MARTYMAR's Avatar
I'll be changing my MAF tomorrow so I'll post the results
Old May 21, 2008 | 08:49 AM
  #34
e30t387's Avatar
s/c 99 c43 amg
well hopefully thats what it is, if not its def the wiring, so ill have to test the ground and stuff not that hard to do but i just hate touching wiring on a car, so hopefully my new maf will fix it.
Old May 21, 2008 | 03:13 PM
  #35
MARTYMAR's Avatar
Waiting for UPS to deliver the MAF now...tired of waiting....
Old May 21, 2008 | 03:32 PM
  #36
MARTYMAR's Avatar
I just received my MAF! About to install it now, stay tuned....
Old May 21, 2008 | 04:03 PM
  #37
Z06EATER's Avatar
1997 C36AMG
ok great
staying tuned
Old May 21, 2008 | 05:07 PM
  #38
MARTYMAR's Avatar
New MAF resolved CEL problem!
Alright fella's,
Can you say smooth operator? No more CEL, engine hesitation or high idling! After installing the new MAF the CEL was still on so I drove it to the nearest autozone to get use the OBD ll reader. I turned the car on enough where the dashboard lights up, connected the reader and received the same code So I erased the code and ran it again...all while the dash is still lit. So then I thought hhmmm it's still grabbing the same old code...so then I cleared the reader again, disconnected it from the car....turned the car completely off, reconnected the reader, turned the car on and it came back with a PASSED reading! ahhhhh finally I am back! It was the MAF all along...it was just bad. I'm good to go now.
Old May 21, 2008 | 06:34 PM
  #39
Z06EATER's Avatar
1997 C36AMG
AWESOME BRO!
Glad to hear your back on track! enjoy!
Old May 21, 2008 | 06:38 PM
  #40
Z06EATER's Avatar
1997 C36AMG
remember to
check your air filter! make sure it's clean these MAF's are a pain in the *** if you don't have clean air coming in. either you got a bad sensor or, ur air filter was dirty?. well good to hear all is well bro
Old May 22, 2008 | 08:05 AM
  #41
e30t387's Avatar
s/c 99 c43 amg
ok received my maf yesterday, installled it turned car on and no mor sputering, so i just hooked up the reader turned car on cleared code while engine ran and went away so im good to go. i was gettin worried thinkin it was the wiring. but now my driver side fog light went out lol, anyone know what bulb our fogs use??
Old May 22, 2008 | 08:13 AM
  #42
ohlord's Avatar
fog
should be H1 55w
or
www.danielsternlighting.com
selective yellow euro spec fog bulb
ohlord
