Installing C43 HIDs on non-HID C43
TIA!
you do not have to buy any special lenses or reflectors, when you purchase a HID kit its just plug and play, kinda like replacing the bulb with a new noe, except the new bulb is a HID bulb.
if it helps, HID lights emit a white-blue light that is very clean looking, you notice these types of headlights most frequently on high-end cars as you may have seen on the road.
HID lights require a ballast to power them, as they step-up the voltage many times to create an arc through the gas element, causing it to glow. HID's are more energy efficient (give off more lumens per watt than standard incandescent bulbs) but you may have to upgrade your fuse to accomodate the larger spike in current upon firing, which then levels out to about half or 2/3rd of the current use that the original non HID light was using.
for example, you have a 7.5 amp fuse for your headlight/s. standard headlamps use about 6 amps consistently. when you fire up a HID light it uses more than 10 amps, sometimes up to 13, and then lowers to even out at about 4 or 5 amps. so even though your new healights use less power thay initially draw more power so you may have to upgrade your fuses to accomodate this effect.
Mine were very easy about an hour to do a properly and secure the ballasts on the inner wings and drill holes through the lamp covers.
My auto level adjust works fine (it do not have auto its just the control knob below the lights switch)
can u post a pic of your HID foglamps in action? id definitely be interested in doing that at some point.
