Fuel Quantity Indicator Failure
Old 05-20-2008, 02:47 PM
FLYNAVY's Avatar
BMW and Mercedes
Like clockwork, my C43 has decided to pop another electrical failure right before service time......my fuel gauge has stopped working correctly. It's basically an intermittant erroneous reading of empty (or close to empty if light isn't illuminated) that seems to generally be happening on hot starts. Perhaps of note, or more likely by coincidence, this was first noted after my most recent trip to the gas station. Not knowing really anything about the w202 fuel system, does anyone have any idea what might be going on? Fuel float failure, CAN failure, ???? Thanks in advance....I'd like to try and take care of this myself so I don't have another $800 bill (for the windshield wiper motor last time).
Old 05-20-2008, 06:20 PM
FLYNAVY's Avatar
BMW and Mercedes
Anyone? bumpity bump
Old 05-20-2008, 06:38 PM
ob1kenobi's Avatar
moon buggy
How's your battery?
Old 05-20-2008, 06:48 PM
whoover's Avatar
'19 E63S sedan
No way to be sure without checking it electrically, but the most common point of failure is the fuel gauge sender in the tank. When in doubt, go with the moving part.
Old 05-20-2008, 06:52 PM
FLYNAVY's Avatar
BMW and Mercedes
Battery is 100%, or at least I don't have any reason to believe otherwise (easy cranking on cold start, no alternator warning light, etc). I figured it probably is the sender....is that a DIY kind of thing, or does it necessitate disassembling the fuel tank? I'd probably be up for that even, but most of my tools are 3000 miles away in storage unfortunately...
Old 05-20-2008, 08:45 PM
whoover's Avatar
'19 E63S sedan
I think there are two senders at the bottom of the tank. I also think you need special tools to get them out and I recall there can be complications. Something to do with the fuel pump and something else to do with new senders possibly requiring version coding with the dealer's Star computer.
http://www.detali.ru/cat/oem_mb2.asp...SGR=015&SGN=01
All told, probably a good one to leave to a pro.
Old 05-20-2008, 09:45 PM
FLYNAVY's Avatar
BMW and Mercedes
Yeah, like I said it is due for a service so at least it's not inconvenient. Definitely seems to be a hot start thing.....anyone know if the sender unit a resistor type unit, or a float?
Old 05-21-2008, 01:46 AM
MarcusF's Avatar
2002 CLK430
The WIS says the first thing to check is that the sender isn't hung up on the fuel line and the lines aren't kinked. Per the C43 secton of the WIS, the R&R procedure is as follows:
You did see the part about "no smoking", right?
Post back whether this helps, if the line was kinked, hung up, and how you fixed it. THanks
Old 05-21-2008, 04:32 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Very common for these fuel senders to fail. The new senders (genuine at least) have gold contacts to prevent premature wear/corrsion. The contacts in the tank can be cleaned but since they are a little more labor intensive than other models to remove from the vehilce then it makes more sense to replace them.
I just had to do it to my car last weekend........not happy!
Probably best left to a workshop to do because it's hard without a hoist.
Old 05-21-2008, 06:33 PM
JRbro's Avatar
1999 C43 AMG
Thumbs up WHACKY FUEL GAUGE
Same problem with my '99...fill the tank and the gauge read empty and the fuel light would remain illuminated. After 50-60 miles the gauge would then move to "full" but would remain "full" for 150 miles or so, then begin to drop rather quickly to 1/2. Really whacky! I read some posts here and was skeptical, but gave it a try and, in fact, the use of fuel injection cleaner does appear to solve the problem entirely! With this last tank, I drove until the fuel warning light went on, added 2 gallons and the light went off and reads just under 1/4 tank, then filled it completely and the gauge reads full!! YEA!!!
Old 05-21-2008, 06:34 PM
FLYNAVY's Avatar
BMW and Mercedes
Any idea what the bill is for this kind of repair out of curiousity? Thanks for the help guys BTW!
Old 05-21-2008, 06:38 PM
FLYNAVY's Avatar
BMW and Mercedes
Originally Posted by JRbro
Same problem with my '99...fill the tank and the gauge read empty and the fuel light would remain illuminated. Drive 50-60 miles and the gauge would then read full, but would remain at full for 150 miles or so, then begin to drop rather quickly to 1/2. Really whacky but I tried, and was skeptica, but in fact, the use of any sort of fuel injection cleaner appears to solve the problem entirely! Since the addition of Gumout injection cleaner, my gauge appears completely normal. The light went on last night, I added 2 gallons, and it went off and reads barely 1/4 tank. YEAH!!!
Maybe I'll try that. On "normal" mode, it seems to be decreasing at a normal rate for the mileage I have covered since the last filling, but I will keep an eye on it. I remembered to set the trip odometer when the gauge failed for the first time (immediately after the filling) so it should give me a pretty accurate guesstimate of when it will need gas. Maybe I just got a ****ty tank of gas???
Old 05-21-2008, 06:58 PM
JRbro's Avatar
1999 C43 AMG
The WIS mentions the gauge issue specifies replacement of the sending units with new ones that have gold contacts; $600-800... Apparently the oxygenates used in gasoline corrode the wiper contacts...
Old 05-22-2008, 12:54 AM
FLYNAVY's Avatar
BMW and Mercedes
yay....thats basically the average then. Not to sound cheap, but I'm not sure why MB can't make a car that doesn't charge you 800-1000 bones every 10 months for random electrical gremlins. And on top of this, I have a phantom A/C sensor failure....like it refuses to turn on the cold A/C air on occaison, and after shutdown and re-start its all good. Man I need to sell this piece of ****
Old 05-22-2008, 06:51 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Awww..is the honeymoon is the honey moon over?
Old 05-22-2008, 11:41 AM
MarcusF's Avatar
2002 CLK430
For the AC, have you gone through the diagnostics via the HVAC controller? Many times it's an inexpensive sensor. IHTH
Old 05-22-2008, 03:57 PM
FLYNAVY's Avatar
BMW and Mercedes
Yeah, I'm pretty sure that what it is doing is just not sensing that the A/C needs to come on.....because the system is 100% otherwise, and has been serviced 3 times in the last 2 years.
Old 05-22-2008, 03:58 PM
FLYNAVY's Avatar
BMW and Mercedes
haha...the honeymoon was over 2 years ago, but this just drives the stake a little further in. It's too bad they couldn't do as well with the "accessories" as they did w/ the drivetrain and body.
Old 05-22-2008, 04:48 PM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
Fly,
My C43 currently is in need of an evaporator, so dont feel bad about your AC issue. i had the EXACT same symptoms when my '97 C280 AC started acting up. Took her to the stealership and 1 evap temp sensor later i was back in comfort. 170 bucks but they didnt charge me for labor, so i guess in this case theyre just a regular dealership, no stealing that time, at least on the labor
Old 05-22-2008, 06:13 PM
fstshrk's Avatar
2007 R320 CDI, 2010 FJ Cruiser, CTS-V
Does this work on the 95s? Probably not since we have a different A/C head unit.
Old 05-22-2008, 07:51 PM
MarcusF's Avatar
2002 CLK430
You'll have to try it. Hold in the REST button and see if the codes are available. I know my W208 has fewer codes available than the W209. I'm guessing the earlier the year, the fewer the codes.
Old 05-22-2008, 07:54 PM
FLYNAVY's Avatar
BMW and Mercedes
Cool, good info guys....I'm glad to at least hear I'm not the only one
Old 05-23-2008, 01:40 AM
SeeKlasse's Avatar
im tellin you, evap temp sensor. the AC would be running good and then all of a sudden the air would turn humid and not cold, this symptom will come and go intermitently until the sensor decides to go bad all the way... just replace it, its pretty cheap
Old 05-23-2008, 05:08 PM
FLYNAVY's Avatar
BMW and Mercedes
haha....I wasn't doubting you man, thanks for the help!
Old 05-28-2008, 03:25 AM
mis-u-jerr's Avatar
1999 C43
Another satisfied customer I see...
I had my fuel sending unit go out twice while under warranty...
Quick Reply: Fuel Quantity Indicator Failure
