Jacking up car with a floor jack + stainless steel brake lines
Old May 26, 2008 | 10:51 AM
fstshrk's Avatar
2007 R320 CDI, 2010 FJ Cruiser, CTS-V
What are safe points to jack up the W202s via a floor jack and then put in jack stands?
I am going to order the service manuals on CD but till then I thought I would ask here.
Does anyone have any pics to safely raise the car and then put in jack stands?
Also, what is a good place to buy stainless steel brake lines?
What about brake pads? I would like a high torque brake pad, dust is not a concern. The brake pads that are currently on the car (not sure what they are) are OK but not great. If I go the OEM route, what brand (Textar, Pagid, Jurid?) should I go with?
Thanks in advance
Old May 26, 2008 | 11:22 AM
FKlammer's Avatar
2000 C43
Wink
I just bought the Mercedes brand pads and AMG rotors for the fronts of my car this past week...approx. $760 in materials on the web. The brake pads were stamped with 'Jurid'. I had someone do the work. Be aware...the brake sensors need to match the pads to clip into the correct location on the pads.
Old May 26, 2008 | 02:07 PM
vinceC's Avatar
2014 ML350 4Matic
Jacking points:
FRONT
Place a 12" piece of 2 x 4 lumber across your jack pad aligned transversely. Lift at the front crossmember just behind the plastic undertray.
REAR
Lift with the same 2 x 4, only aligned fore and aft under the differential.
JACK STANDS
Place under the rubber jack points along the bottom of the rocker panels. They are in line with, but below, the jack ports for the emergency jack that comes with the car.
If your car is lowered you may have to drive it up on some 2 x 12 lumber to get it high enough to roll the jack under it.
Old May 26, 2008 | 02:58 PM
fstshrk's Avatar
My car does not have the rubber jack pads unfortunately. Do you happen to have the part numbers so that I can order these from the dealer? Alternately, I guess I can always use the hockey pucks
The car is low, so I will definitely have to get on the 2x12 lumber pieces to get a jack underneath.
Thanks again!
Originally Posted by vinceC
Jacking points:
FRONT
REAR
JACK STANDS
Old May 26, 2008 | 07:16 PM
vinceC's Avatar
2014 ML350 4Matic
The pads are PN 001 997 95 86. They have a rather exotic description - "Plug, workshop lifting jack take-up device in side member, bottom, 28 mm".
If the dealer has trouble finding them in the EPC they are listed in Group 60, Shell, Grommet, 030 Expansion plugs, grommets.
The pads are a round pad with an expansion plug that you drive home once the pads are located in the side member. They won't protrude far below the side skirts on the C36.
Old May 26, 2008 | 07:53 PM
fstshrk's Avatar
Hi
Do you happen to have the part numbers for the height adjustment shims by any chance?
I checked today and I think I am going to need a #3 or #4 on all four corners.
Thanks in advance,
Old May 26, 2008 | 09:57 PM
vinceC's Avatar
2014 ML350 4Matic
I posted them on your other thread a few days ago.
https://mbworld.org/forums/c36-amg-c43-amg-w202/244796-ride-height-adjustment-pads.html
Old May 26, 2008 | 10:15 PM
fstshrk's Avatar
Much appreciated. Somehow I missed this post.
https://mbworld.org/forums/showthread.php?t=244796
