C36 engine ??'s
Any suggestions where my problem may lie?
thanx
JC
Also check to make sure your rubber ribbed intake boot (the one right after the MAS) isn't cracked on the bottom side. Those are very prone to cracking, could be a potential vacuum leak as well.
Dr.C36 there is no problem with any part of the intake that I can spot.
On that same note. I saw a thread once about a guy who makes wire harnesses. Anyone know who that was?
You may want to stop by a mechanic with a real time monitoring device (as opposed to just an OBD-II scanner) and go for a drive with the monitor hooked up.
