Performance cats?
https://mbworld.org/forums/attachmen...1&d=1215728710
How does it run? sound?
I've had this warped idea of putting in an electric exhaust cutout after the [stock] primary cats - with the dump in front of the passenger rear wheel. I'd connect the cutout about where the two pipes bend back to the center of the car before the resonator. However, I can't come up with a design that will work because with the two primary pipes side-by-side on one side of the car, there's no apparent way to connect the inside pipe to get it to the outside on the passenger side. I was thinking of maybe putting in an H-pipe or X-pipe between the two primary pipes and connecting a single cutout from the center of the X-pipe. It's all probably a pipe dream anyway!!!
