Performance cats?
none
Do an online search for "metal cats". They are 200cel stainless construction and super small which is important for our setup. The construction is quality and they have a very good reputation. I've had mine heating up under the car for over a year and they are still shiny actually![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I assume this is for the secondary cats? What are your exhaust plans? Personally I replaced the secondary's because I plan on eventually installing headers without the primary cats. The primary cats really suck on our chasis and they are so hot and close to the motor. If you are going to retain the primarys and depending on emissions in your area I would consider removing the secondarys all together.
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
im just trying to tally up a comprehensive list of items which i need to make my exhaust system nice. nice as in performance oriented, but the sound needs to be respectable aka not too loud...
decent headers, highflow cats, y pipe with 3 inch all the way to muffler... is there an option for the primary cats?
these are the new gen2 Vibrant cats, much less ghetto than their gen1s, their price is very affordable too, only $109 compared to $180 a pop for "Metal Cats". They are 200 cell and they come in 2.25" / 2.5" / 3.0" respectively (look at links below).
http://cgi.ebay.com/ebaymotors/2-25-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/2-5-S...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/3-Sta...QQcmdZViewItem
Hope that helps
Hope that helps
I'm running 200 cel Metal'cats like Nitro. I've also heard a lot of good things about Random Technologies cats also VRP has hiflow cats for the W211 E55 boys that may work for your car. You might want to give them a call.
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Random Technology is the premier spun metal cat...but consider the Magnaflow equal for half the price.
magnaflows are always a safe bet. just make sure they are true metal 200 cell race cats and not the conventional ceramic grid core cads. sometimes on ebay they label one as the other.
none
The work involved to replace the primary cats would probably make it not worth it. The secondary cats are easy access but the primarys would require removing the down pipes from the manifolds. Also, you would need to modify the ends of each cat to the angles that match the stock cats. Take a look at the primary cats and you'll see what I mean. This is why I like the kleemann headers as they delete these.
I rattled the bricks out of OEM SL500 cats on the dyno.
The Magnaflows or the Random Technology are only about 8" long and 4" diameter, so no precats used.
High flow and take higher heat then the older ceramic brick technology.
http://www.planetmagnaflow.com/shop/...59954-686.html
Your Fulton county GA emissions check for a 1998 only involves a code scan and visual inspection for cats. There is no exhaust gas sampling
ABSOLUTELY get headers that extend past the primary cats and eliminate them !!
THEN after you have completed that substantial upgrade, swap the standard (secondary) cat's with some high-flows.
THEN, if you're even still in need of any additional exhaust work, slap a Remus cat-back on there.
remus doesnt make cat back exhaust for the c43. a remus rep told me that they made a couple lots of amg mufflers for mercedes so they dont manufacture aftermarket versions... wether thats true or not they dont offer a cat-back with 3 inch piping thats for sure...
isnt that the stock pipe size going to the muffler? either 3 or 2.75 it looks really fat... was stating that remus doesnt make mufflers with a 2.75 or 3 inch pipe
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![word](https://mbworld.org/forums/images/smilies/werd.gif)
Here's a gift just from ME doing an online search:
http://www.prostreetonline.com/s/exh...er-muffler.asp
you can go black stainless or silver stainless
http://www.vibrantperformance.com/pr...05/pg20-21.pdf
This muffler is also lighter than the stck muffler.
C55,
are you using the stock downpipes to 3" cats leading into a custom catback or are you using aftermarket headers which eliminated the precats?
is there an application for a X or Y pipe in these cars?
When the upper/primary cats get deleted on our c43's what happens with the O2 sensors? Do they care the cats where removed? In other words will the computer throw an eror code?
Also, will there be any gain in HP or MPG when they are removed?
Changing cats will not cause an error code.
Make sure you get a spun metal cat that meets federal requirements.
You should have no problem passing emissions with a performance cat
none
In terms of the O2's you will need to weld in some threaded bungs for the secondarys. The C43 picks up from the primarys, which is why people can simply delete tthe secondarys without issue. Just move em' down stream to read the secondarys.
I don't know of anyone who removed just the primarys..its usually a combination of headers and downpipes without the primarys. Kleemann feels its important. If you were able to remove just the primarys I'm certain it would help performance. For one, the cats are restrictive. Also, next time you go for a spirited drive pop the hood and look at the primary cats location(AMG had little room to work here) and feel the heat they throw off.
Thanks guys!
So I CAN delete the primary cats with no issues and MAYBE some extra ponies,correct? BUT, to pass emissions and not get any codes I will need to hook up the secondarys O2 wires to the primary wires??? This part I am VERY confused, sorry. Can anyone explain this as basic as possible?
I read the part about making new threaded bungs but dont get it wy I would need this if there are bungs already. Cant I just use the wiring from the primarys to hook up to the O2 sencondary bungs?
Sorry very confused.
The stock sequence goes something like this. The exhaust exits the engine into the exhaust manifolds. Then there is the first set of o2's (one on each side of the engine) that read the AF mixture of the engine and tell the computer how to tune the car. Then there is the set of primary cats. After the primary cats there is another set of o2's that check to make sure the cats are functioning properly. After these o2's are the secondary cats. There are no o2's after the secondary cats so the cars computer really doesn't know if you remove them. If you decide to remove the primary cats (while retaining the secondaries) the car will know something is up with your primaries. The solution is to keep the first set of o2's in place but move the second set of o2's (which used to be behind the primaries) behind the secondaries. This way the computer will see cats that are functioning and not know the difference.
i see.... one thing thats bothering me is i had my mechanic change my o2 sensor (pre-cat driver side) recently and i was watching him do it from under the car, fot he primary cats start after the downpipe clears the motor area?
