Will these fit?
Old Aug 31, 2008 | 01:22 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Originally Posted by SeeKlasse
ill take ur word for it oc . man i really want those wheels. can anyone photoshop 'em onto a w202 to see how they would look? i think theyre the same style as the CLK BS wheels...
I'll do even better!
http://club202.com/forums/showthread...threadid=14962
Old Aug 31, 2008 | 02:56 PM
bagelsjustbagel's Avatar
In search of W222
Anyone know where to get cheap black brabus reps. I want them as big as possible, but without rubbing issues or fender rolling needed.
a link would help
Old Aug 31, 2008 | 03:26 PM
OCKlasse's Avatar
MBworld Guru
a link would help
Why is fender rolling such a big no-no?
Old Sep 1, 2008 | 02:27 AM
In search of W222
its not really a big no no. but i either want 18's or 19's i guess if fender roling HAS to be done. but the closest i want it to look like. is like Z06Eater's (Lenny's) car.
Old Sep 1, 2008 | 01:59 PM
OCKlasse's Avatar
MBworld Guru
Then 18s will be fine. If you're looking to be low with 8.5 and 9.5, be ready to roll your front fenders though (the rears come rolled from the factory).
Old Sep 1, 2008 | 07:21 PM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
OC, youre tearin it up! thanks for the reference pics, that 202 looks so sick... i really want the wheels now...
Old Sep 1, 2008 | 07:37 PM
  #32
SeeKlasse's Avatar
oh btw, im runnin the stock springs (4 finger gap in front lol) so i probably wouldnt have to get the fenders rolled or smaller tires in the front until i drop the car right?
Old Sep 1, 2008 | 09:38 PM
  #33
OCKlasse's Avatar
MBworld Guru
Not with 225 and 255 you shouldn't have to.
Old Sep 1, 2008 | 10:50 PM
  #34
SeeKlasse's Avatar
those wheels were rockin 255/285
Old Sep 4, 2008 | 11:02 PM
  #35
In search of W222
How about these...
2 = 8.5Jx18H2xET35 and 2 = 9.5Jx18H2xET35
and how about these (these are blackk)
the wheels are:
18x8.5
18x9.5
and the tires that are mounted and balanced are:
225/40/18
255/40/18
Old Sep 5, 2008 | 12:23 AM
  #36
EVLC36's Avatar
2005 C55 AMG
The rears should be 255/35/18, not 255/40
Old Sep 5, 2008 | 12:49 AM
  #37
In search of W222
only the rears not the front's too?
Old Sep 5, 2008 | 08:27 AM
  #38
SeeKlasse's Avatar
do some research. the "40" or "35" is a relative value. it determines the sidewall height. the relevance is to tire width, i think its a percentage. if you have a wider tire in the rear than in the front, in order to keep the sidewalls a consistent size, the wider tire is going to be the one to have a smaller value for sidewall...
Old Sep 5, 2008 | 06:55 PM
  #39
In search of W222
Im about to grab my 97 C36 tomarrow.
i checked it all out including the engine manifold and all that good stuff.
it needs new tires.
so i figure i might as well get new rims @ the same time
What type of tires should i get to go with this?
http://sfbay.craigslist.org/sby/pts/823641898.html
Brand? model? deminsions?
I know alot about cars. But im a noob when it comes to RIMS+TIRES
Thankssss
~Adam
Old Sep 9, 2008 | 11:23 PM
  #40
In search of W222
IGNORE THE POST ABOVE THISS
http://www.tirerack.com/tires/tires....tnum=44WR8Z1SS
Will those fit? IM guessing so
Also, the reviews seem to state that they are fine for usuing in Bay Area Style Winters (Cold rainy. no snow, no ice, no hail)
Old Sep 10, 2008 | 03:12 PM
  #41
SeeKlasse's Avatar
eh. pretty expensive. tirerack doesnt sell toyo, but try to find some toyo px4's. theyre great tires. 120 for each front one and 130 for each rear one... good treadwear and, of course, great performance.
Old Sep 10, 2008 | 05:47 PM
  #42
ohlord's Avatar
Toyo
proxie4's drive up to Sacramento les schwab tire center,toyo even makes a higher rated performance tire and the new big les up north of you has the latest hunter alignment machine if you are dropping the suspension.
http://www.1010tires.com/TireSizeCal...?action=submit
for the guy that was wondering about tire profiles and aspect ratios,you want to keep your rolling diameters the same front to back and close to oem tire height.If you don't your abs,cruise control,esp will all be screwy
to say nothing about how far your speedometer will be off.
Old Sep 10, 2008 | 06:44 PM
  #43
In search of W222
Thats not too bad
i ended up buy Michelin Ps2's
280each!!
but they are rated for 6 years no matter what warrenty and all this other good stuff. soo if i burnout alot and use them before six years is up, they will give me a new set for free. =]
besides there is no question about grip.
They put them on Mclaren F1's =]
Old Sep 10, 2008 | 09:31 PM
  #44
SeeKlasse's Avatar
negative. youre going to get screwed bigtime with PS2's. youll be lucky to get 12k miles out of the rear tires. those tires are going to be gone within the next year and youll have wasted over a thousand dollars!
why do you think i put toyo proxes on my car after burning through sets of pzeros.. because it really doesnt matter what you use, youre going to get good traction regardless. you might as well try to get a few extra miles between new sets and maybe not spend so much each time
Old Sep 10, 2008 | 11:11 PM
  #45
In search of W222
they have a costoco warrently, so if they go out before 6yrs (predicted wear) they replace them for me new set. aka every time i start to get low... go sum burnouts and Get NEW ONESS
Old Sep 11, 2008 | 02:50 PM
  #46
SeeKlasse's Avatar
theres no way. that is horrible business practice, theyell never make money offering 12k mile tires with a 6 yr warranty without some type of mileage regulation.
costco isnt stupid. u probably misread. 6 yrs at standard yearly mileage of 12k per yr is 72k miles.... i dont think so. they did not predict that those tires would wear in 6 yrs, youre out of your mind!
Old Sep 11, 2008 | 02:57 PM
  #47
SeeKlasse's Avatar
you misread.
http://www.costco.com/Images/Content/Misc/PDF/TIRE.pdf
60 months. thats 5 yrs, and its road hazard. it states in there that if the tire is worn down past a certain point, it is a worn tire... which means you buy a new tire.
this forum exists for a reason - for us to share our experiences. unless your parents are nice enough to buy you a new set of PS2's every year, you should have listened to people's advice and gone with a more economical choice. just because the michelin ps2 is the highest rated tire grip-wise doesnt mean that youre going to be able to tell a noticeable diff between those and a set of toyos, which would have cost you less than 700 for the set mounted, balanced, and aligned.
Old Sep 11, 2008 | 05:16 PM
  #48
ohlord's Avatar
Pro rated
tire wear,if you wear out half the tread depth in 6 months of a 5 year tread warranty ,they might replace them but you will pay for the half life used.
less the exclusions,and they are no fools when looking at an AMG with tires smoked to half depth in 6 months they know for certain you violated one of these exclusions
2. A tire that is damaged / failed due to an accident.
3. A tire that is damaged / failed due to commercial use.
4. A tire that is damaged / failed due to racing.
5. A tire that is damaged / failed due to Off-Road use.
6. A tire that is damaged / failed due to snow chains or studs.
7. A tire that is damaged / failed due to rapid or irregular wear.
ohlord
Great tires ,but in recent tests the proxie4 and the higher rated toyo from les schwab rated equal or better and the new schwab stores have the latest hunter align machine,will install spring kits for a drop and install camber kits and links to get it into spec.
either way you go the biggest increase in tire life is a proper alignment.
and not toasting them every stop light
Old Sep 11, 2008 | 05:18 PM
  #49
In search of W222
well my dad has had his michelins for 4 year and they are fine
and yeah i know that the forum is for adice.
NEXT TIMEEE
and no my parents dont my them for me
i spent MY $ on them
Old Sep 11, 2008 | 07:28 PM
  #50
2PHAST's Avatar
500E Signal Rot
A 18x8.5 in the front is pushing it. I ran a 18x8 in the front of my C36, which was lowered about 2 inch's and had rubbing problems, as AMG only rolled the top portion of the fender lip, they did not roll it all the way, something I had to finish.
No way I could of run a 8.5, unless I went with a much smaller tires stretched onto the rim, which is something that should NOT be done.
Stick with the proven size, 18x8 and 18x9 with the 31mm offset (AMG monoblocks)
