upper intake removal m113?
#51
sounds like airplane
wait- yours isn't connected?
wtf is it?
I know I don't have a logical place for it to hook up to or anything, but I got confused and stopped putting things together when I saw it.
wtf is it?
#52
Please don't follow this advice.....
Here is a pic I snapped at work, I think you'll be able to tell from this Drew.
The male portion of the sensor clip is wired into the fuel rail wiring harness and should be hanging within inches of that. The vacuum line goes into the EGR valve bell looking piece that contains the valve.
[IMG][/IMG]
[IMG][/IMG]
#53
ya, figured out the fuel rail clip now, new wher the vac line went, but still what is the black circular plug thing? I've got it al ready to go together but for the life of my lost on that piece- I think that was what he was saying to leave hanging?
#55
1990 300ce supercharged and intercooled
the unit is the egr and switch over valve. the round thing is just a vent. when vacuum is released air is vented in to close the valve. the vent has a filter in it. it is not necessary but should be repl when you have a chance.
#59
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
Completely reseal? Are you talking about where the manifold bolts up to the head? BC I only used the factory manifold seals and it's having what I think is a a vacuum issue. The WIS didn't mention a full gasket either...
#60
I know this is an oldy, WIS says the manifold is not serviceable and you should never open it.
Has anybody successfully resealed one? I would like to know as mine is full of carbon and could do with a clean out before I reassemble.
cheers,
cheers,
#61
I know this is an old thread but perhaps I can get some help. On the picture, the yellow is where the outside gasket goes. Is the area marked in blue where I would apply gasket maker?
#62
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I think that gasket maker needs to be applied as your picture shows. Nice clean manifold You are a very brave man to have split the manifold. We have heard of plenty of bad stories of faulty reseals with leaks difficult to trace after...
I wonder if there are other means of removing the oil build up inside without splitting or changing the manifold. Perhaps ultrasonics?
#63
yes, it was a huge pain in the *** to get everything cleaned.
