What needs changing after nine years and 70k miles.
- all fluids, including flushing brake system.
- ck belts and replace as needed
- plugs and wires, distributor?
- fuel filter
- inspect and replace engine mounts as needed
- suspension, inspect and replace all worn parts - bushings and ball joints most likely
- maf ?
- cabin filter too!
- pop the cover of the monwiper ad hit it with some white lithium grease
- check the date on the battery
- CPS - crank position sensor (** a must - u may ended up being stranded)
Can you guys add to the above? This noob needs some help...
- fuel filter
- maf ?
- cabin filter too!
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
CPS - crank position sensor.Trust me , its easier to change on your terms than on the cars terms.Was the harmonic balancer changed (factory re-call work) ? Tranny flush ?Also , I would pop the cover of the monowiper ad hit it with some white lithium grease and change!You might want to check the date on the battery too - I had mine for 8 years.
CPS - crank position sensor.Trust me , its easier to change on your terms than on the cars terms.Was the harmonic balancer changed (factory re-call work) ? Tranny flush ?Also , I would pop the cover of the monwiper ad hit it with some white lithium grease and change your cabin filter too!You might want to check the date on the battery too - I had mine for 8 years.
Flex discs.
Do 202's need their steering bolts retorqued every 4 years/50K? If so, that's a 90 second job. It's regularly overlooked by the W208 crowd.
The wheel bearings should be repacked.
I'd plan on changing all the coolant hoses every 10 years.
- fuel filter
- maf ?
- cabin filter too!
- fuel filter
- maf ?
- cabin filter too!
Springs delivered!
Transmission fluid ordered!
Transmission kit ordered!
Fuel filter ordered!
Spark plugs ordered!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Tom' ordering MAF insert and CPS.
I know you are new to C43 so I just tjhought id let you know that c32 brakes work on a c43 without any mods and I think they are less expensive, not as good as c43 brakes tho
something to consider, I personally would only do it coz the c32 calipers look better
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
