instrument cluster light change...help!!
two days ago when i turn on my lights, one of my guage(instrument cluster, the temperature in particular) is acting up, i have to flick the plastic cover before the light actually turns on....can somebody help me and walk me through this..thanx in advance
1999 W210 E300 Turbodiesel
thanx for the help sir...what clips are you talking about from behind the cluster??? do i just have to push the cluster from behind or i still have to take clips or tabs from behind the cluster? coz i look like its kinda too tight from behind the cluster...thanks for your help again. hopefully i can take care of these, this weekend
u have open the lower panel and take the clips out from the back out Cluster , u have to put your hand from lower panel to the back of Cluster and lose the clips, once the clips are lose u can pull out the cluster Easy
1997 C36 AMG
Cluster Removal
Cluster removal is simple and easy - with the right tools. There is no need to remove panels, etc and there are no clips to remove.
I had a light issue last year and paid the Mercedes dealership $50.00 to change the bulbs. I watched the mechanic remove the cluster in less than a minute with a Mercedes cluster removal tool - which I purchased myself shortly thereafter. The part number140 589 02 33 00. They do not like to sell them, but if you have a good relationship witht the parts staff, there should be no issue.
I hope this helps!
I hope this helps!
