C43 Service
BMW and Mercedes
C43 Service
With all the free time I have been having on weekends lately, I'm thinking that I will try and knock out my next service on the C43 myself (not to mention the nearest stealership is 100 miles away and not really an option on workdays with any convenience). Anyone have a basic shopping list of everything that is normally included? I think it is up for a B service (the lengthier of the two IIRC), so I guess that is what I would be doing. Any help is appreciated, thanks!
If it's the same as a CLK430, this is what the dealer does.
Generally
A glorified oil change,fleece filter of course autohausaz.com 16 bucks.
Mobil 1 0w40 2bucks off a quart up to 5 if you join their rewards program.you get 2 coupons so that is $20 on 10 bottles.
Most models won't be far off if you follow
A-Service — First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
B-Service — First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of front and rear brake discs
· Check front and rear brake pads for lining thickness
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Check engine cooling system, antifreeze and corrosion protection
· Check brake system
· Check power steering
· Check windshield washer system
· Check condition of poly V-belt
Trunk
Don't know how many miles you are pushing but it is probably past due for a trans fluid and filter change.MB spec 722.6 fluid only.PM if you need the special dipstick.PM if you are doing plugs,I also have the special 17mm offset boot tool that makes plug changes a snap.
Change your rear diff fluid mobil 1 syn 75-90 wt.
Have fun![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
"GOT CODES?"
Interior
· Function check
Wheels, brakes
Engine compartment
· Brake system
Trunk
Services performed:
Interior
· Function check
Wheels, brakes
Engine Compartment
Trunk
Have fun
"GOT CODES?"
BMW and Mercedes
Yep, DEFINITELY time for the trans fluid change (just broke 100k miles recently). Thanks for the links, really appreciated! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Also, does anyone know the stock wheel lug nut size? Is it 18 mm?
