Ohh no..CEL P0141 Guessing o2? Freeze Frame Data Included, Need some OBDII Experts...
I'm hoping there are some OBDII code experts that can give me a definitive answer.
CEL came on, recieved generic code P0141 "02 Heater Circuit" (Bank 1, Sensor 2)
Freeze Frame Data:
Fuel Sys 1: CL
Fuel Sys 2: NA
Calc Load(%): 18.43
ECT(celcius): 86 degrees
MAP(kPa): 27.00
Eng RPM: 2688
Veh Speed(km/h): 18
I'm guessing o2 sensor. How many are there on a 95' C36 (Have not looked underneath her yet) Pre cat and how many after cat if any? Please "learn" me guys!
Thanks for the help so far guys!
btw my car now only has one since i have no cats, and on a scan it throws no errors, guess cause i dont have the CEL and its systems check.
i did install a wide band for a test un the other day, the car on WOT ras as follows:
below 2800 to 3000 rpm AFR is abt 14.
above 3000 till red line its at 12.8 steady, but at 3600 rpm (the famous flatspot) the afr rises slightly to 13.1 to 13.2 then by 4000 its back to 12.8.
so at 3600 it seems the resonance flap change over disrupts airflow for a fraction of a second. what do u think guys??
So below 3000 rpm we can benefit if we drop afr to abt 12.8, guess that’s y a superchips is said to improve low rpm pickup.
To be honest with you the problem with soldering stainless steel is the problem of how fast it oxidizes and the type of solder you use. Acid based flux and silver-cadmium solder will do it with no problems whatsoever with a pencil iron. Even simple 60/40 tin lead solder will work flawlessly with proper fluxing procedures. Basically, while your applying the solder, put a drop of muriatic acid. If one can't get such a dangerous acid
apply tons of generic acid based flux before and during your soldering procedure and you will be amazed! Any acid based flux should be sufficient. Just don't breathe the fumes in or get it in your eyes (it stings...badly).FLUX is the absolute key when soldering SS. However, after all that I will most likley just crimp the connectors on and then solder, just because I'm a soldering junkie
. Hope this info may help some others in the future when they run into problems with SS soldering to steel or copper wiring....Flux, Flux, Flux....or muriatic acid
[COLOR=black][FONT=Verdana]btw my car now only has one since i have no cats, and on a scan it throws no errors, guess cause i dont have the CEL and its systems check.
Lak shu dude!
Now that you removed your cats, you're drivin' freeflow!
The car runs much better I guess?
Which octane do you use for pumping gas?
The higher octane gives more feedback in combustion when driving fast, your car feels stronger and faster!
The higher octane is good for turbos and special tuned cars that needs 100 octane!
Or Shell's V-Power 99.
You have this in Lebanon?
Do you have any government regulations for annual vehicle inspection?
Complete check ups for safety and enviromental issues?
Is it legal to remove the complete cats?
Maybe you can mod your car what ever you like to do?
Lak shu dude!
We do have a yearly strict check up on saftey and emissions but as long as my car is well tuned and i can pass emissions with no cats.
Yes we can mod cars alot here but it need to be safe and with good emission control on idle at least.
As for fuel we have 98 octane at the pumps but some places even sell Avation gas and race gas, but 98
is good enough for the AMG for now.
I've sen your videos on jutub!
you drive like you stole the car!
inner roof lining is bouncing around when you drive on these rugged roads in Beirut!
Now that you don't have any cats car feels faster and it gains a few extra hansirs!
well if your car runs perfect with that set up then continue with it!
It's a winner!
shukram habibi
jalla bye
The rear will throw a cel as its there to confirm that the cats are doing the job..
And your 93 octane is the same as our 98. marcusF prolly can explain better.
You can fill up your car with any type of gas you want without killing your cats?
In Lebanon do you have leaded gas or only unleaded but in various octane?
Do you always pump 98 octane, if pumping lower octane does your engine pinking?
I think this was the correct word for low premium gas? (pinking)
Does any country have leaded gas for cars nowadays?
we only have unleaded in either 95oct or 98 oct. as i said some special pumps sell AVGaz, and some sell race fuel.
98 sells at USD1.1/liter today, but every week the price is adjusted according to oil prices.
Yeah for $1.1/liter US D. is about 8 swedish kroner!
That's ok liter/price.
In sweden 1 liter is about $1,65-1,70.
Gas is not cheap in western europe!
cheap gas only in old Russia!
Pumping race fuel or AVGaz is cool but I guess it's a very costly expense?
But your car will run like shajtan/haiwan!
For reference G3/2 is the front sensor (sensor 1), and G3/1 is the rear sensor (sensor 2). Confused yet?
So the rear one even if its dead will only throw a CEL but wont affect the idle, running of the engine.
BTW after clearing codes it has yet to come back.....? who knows, still montoring cycles though....
