C43 oil leak from the front
http://www.autohausaz.com/search/pro...Cover%20Gasket
Should be the gasket pictured on the bottom.
I saw the squared gasket #ps linked from autohaus on previous tread!
Now I don't know the #ps numbers for the gaskets on upper oil cooler!
The oval gasket and the smaller round gasket!
Can you link the parts numbers from autohaus or another webshop with MB #ps numbers?
Thanks for the #ps numbers!
How much did you have to cash out for em'?
Was it Elring gaskets?
I mean they should be made of good quality materials!
Anyway, I bought both because I wanted to be certain I had the right one, once I open it up I will know I guess.
But then it occurred to me - can I use the updated seal even if I have the old one in the car right now? Or are there physical changes on the cover? I think my engine serial number indicates the earlier seal should be used, but the parts guy wasn't very clear on the issue of superseding parts numbers. Given the relatively small cost, I bought both.
sensor 1 has the engine serial number 00 24 20 and it had 2 clip on locks!
sensor 2 has the engine serial number 00 24 21 and it had 1 clip on lock!
The serial number on the engines does not match the serial numbers for these timing case gaskets above?
How come all 4 parts use different numbers for engine serial numbers?
regarding the cps sensors if they show the engine serial number then it should be the same for those timing gaskets!
same engine S.N.!
I have changed my cps just in case so no worries there anymore!
I just bought my front suspension parts today from a US webshop and for a cheap dollar I feel rich buying from the US instead of sweden that have NO competition in prices for cars between shops!
sweden sux when it comes to buying parts for my car!
way to expensive, we have added 25% government tax on every part or any product from clothes to electronics!
buying stuff in sweden is crap!
Under the car looks like this
If there are certain things other members have experience of being easy of enough, I can do it myself. I work on all my vehicles. Also at the same time I want to be specific when I bring it to the shop as where and what I suspect the problem is. I hate when a shop does trial and error , and find the error on the final try. I want to have my ducks in a row this time . Thanks in advance
Here's a good YouTube video on some of the common/easy to fix oil leaks.
