Cooling Fans and Compressor Questions
As for the fans coming all all the time they will come on often but not full speed constantly unless it's very hot. First thing is to make sure your viscous coupling is working ok otherwise it may be a case of the aux fans making up for an inop main fan. What's the ambient temp when you're checking it?
Did you regas the system yourself? If the system wasn't vacced down sufficiently or the gas used was poorly handled previously (ie air in the bottle) then you will get very high condensor pressures which make the fans stay on all the time at full speed.
Common values used are 1 interior temp, 2 ambient temp (raw value from sensor, not "dampened"), 3 heater core temp, 5 evaporator temp, 6 engine temp, 7 condensor pressure in bar, 8 condesoner temp.
Press the rest button again to exit the menu.
With the a/c on the lowest temp and fan on full and engine idling for 5 min, go the values 5, 7 and 8 and post what the pressures and temps are.
Secondly for those ambient temps the condensor temps and pressure don't correlate correctly. http://www.glacierbay.com/ptchart134a.asp I would be guessing that you have a portion of air either in the system when it was charged (not vacced down sufficiently) or the gas that was used already had some air in it. When there is air in the system the condensor pressures go up rapidly but there is very little heat.
I'll have to check on the evap temp sensor, I've never had to change one. I know the W210 needs the dash removed but that may not be the case for the W202
