I bought the reardoor sunblinders!
About installing them, how do I do that?
There is a small metal bracket on the blinders end (adjusting with 2 small screws for fitment) to press down in the tiny gap between the innerlinig doorpanel, pointing out to the C-pillar.
And there is another loose metal fastener that snaps on the horisontal window frame between large window and the smaller window on rear door!
There are some hooks that snaps on the window when rolled down.
The innerdoor panel looks to sit tajt to the door and there is a tiny gap to press down the blinders metal bracket into this gap!
On the innerlining door panel pointing in near the door knob B-pillar the inner panel is to tajt without any gap to press the other side bracket from the blinders end!
Are there only 2 fastening brackets to be stuck on the door?
Does anybody have these MB rear door blinders?
Tell me how jou installed them.
thanks for putting up the pictures.
I just took them out of the box, and I saw there is 1 bracket on each side on the blinder ends!
I looked at the innerdoor panel and there is a tiny gap on the outer side panel next to the C-pillar where I can press the end bracket into this gap to sit tajt!!
The inner side panel next the B-pillar is tajter without any gap to press the bracket end into this gap.
So what do I do?
Did you have the electric rear window sun blinder installed or was it a manual pull?
# all ps numbers would have been great to have to retrofit the el.blinder.
I bet the rear deck shelve must be replaced to another one????
Thanks foe the pictures coming up!
thanks.
about the fasteners, the bracket fastener on the window, do you have to press the metal bracket between the window pillar and the lining?
this metal bracket that is folded, shouldn't this bracket be put outside this windowpillar and then snapped around to sit tight?
my inner door panel sits very tight on the innerside towards the B-pillar!
there is no gap for the metal bracket to be pressed in!
there is only a gap on the outerside panel to press down the blinder bracket.
hey Appatula.
Your rear doorblinds are they in anthracite grey/blackish color?
they seem to have a lighter color shade than your rear window blind which is black?
I have fitted my rear doorblinds to my car and I guess I have the same color shade on my blinds as on your car.
Now only thing missing is rear window blind.
these parts are an awesome option because they will keep your car more cool and you'll keep your leatherseats protected from sun.
