We're Back!!! Our Adjustable Camber Arms
Old May 3, 2010 | 03:52 PM
TVT_DESIGN's Avatar
Former Vendor of MBWorld
Chrysler Crossfire
http://www.tvtdesign.com/
We've had these out for a couple months now and the reviews are great.
Our arms are made of High Strength aluminum. The rod is 3/4" in diameter and is clear anodized. The Rod Ends are over sized and anodized Red. We also include SS spacers for a direct fit.
These arms will allow you to dial more camber then the car can handle (+/- 5 degrees). Completely unnecessary, but for that one customer that wants to run crazy negative camber, it works.
Check out the link at the top and scroll to the bottom.
Old May 4, 2010 | 08:28 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Welcome back Anthony !
Old May 4, 2010 | 12:04 PM
jayrasheed's Avatar
1995 C 36 AMG; 1992 W124 300E (M103 Ex Mosselman TT KIT) was 320hp @10psi now stock :(
anythong for the darn front control arms, i need camber there!
Old May 4, 2010 | 01:39 PM
TVT_DESIGN's Avatar
Chrysler Crossfire
Front camber bolts?
Old May 4, 2010 | 02:29 PM
jayrasheed's Avatar
Originally Posted by TVT_DESIGN
Front camber bolts?
and whats the adj range on those?
Old May 4, 2010 | 02:49 PM
Saaboteur's Avatar
eclectic assortment of cars
K-Mac has adjustable front camber/castor set up. I picked up a kit, but have not yet installed it.
Old May 4, 2010 | 03:14 PM
DRBC43AMG's Avatar
K-Mac
You can find them here: http://www.k-mac.com.au/
Old May 4, 2010 | 06:30 PM
TVT_DESIGN's Avatar
Chrysler Crossfire
We use the OEM MB bolts for the front. It allows +/- 2degrees I think, it may be 3. They are an easy bolt in and are pretty cheap.
We've heard a lot of complaints about the over complication of the K-mac kit. No personal experience, just feed back.
Old May 4, 2010 | 07:38 PM
kinghais's Avatar
1999 W210 E300 Turbodiesel
dam cheap S**t!
don't even waste ur time, buy good quality
Old May 4, 2010 | 09:22 PM
TVT_DESIGN's Avatar
Chrysler Crossfire
Originally Posted by kinghais
dam cheap S**t!
Um what?
Old Aug 27, 2010 | 01:16 AM
jumph4x's Avatar
W210 DRFT BNZ
Sent you guys a message through your site's contact form
Though the claim that the factory bolt kit for the front does 2 degrees is way off from what I understand. The eccentric bolts run about 20' which is one third of a degree.
