So.... add limited slip?
I remember seeing some spring block on ebay awhile back that would let an open diff work similar to a LSD when installed, anybody remember this?
caution wag alert: Or is it that the traction system will tell the TCU the wheel speed, and the TCU (who knows the output shaft speed, and based on that is pretty sure what the rotational speed should be) will throw a fit and do something highly undesireable (like limp home mode)?
The transmission ECU uses both rear wheel speeds then averages them out and multiplies it by the diff ratio programed to determine the transmission output speed. If the diff ratio is changed and not reprogramed then it will get a output speed it isn't expecting so it will throw a code for "implausable ratio" and lock itself in a gear until next restart.
Some tuners can change the ratio or you may be able to recode if you get the appropriate codings (not a straight forward excercise). Id probably try using a transmission ECU from the car you take the donor diff out of if you were going to try it, but expect problems.
A W208 diff is interchangable but you need to replace a few other things like rear driveshafts and the diff ratio is longer so you will loose some acceleration. There are no dirrect swaps for a shorter ratio.
Basicly the main 2 options available for LSD's is either Kleemann or Phantom grip. Both are a spring plate between spider gear types. I've also recently found that Drexler (German company, do a search) make a proper LSD for many different Mercedes models including C43's (but you would need to double check with them)
How is the reliability on these, has anyone on here done the Phantom Grip one?
Pretty cool stuff, alas pricey.
I did have the diff carrier shaft roll pin shear into two pieces that did cause me to lose control and total my previous C43.
But with a better piece of metal used in place of the stock roll pin the unit still works very well.
I would say go ahead and buy the unit.
Jeff
Jeff
