Climate control unit
Old 07-01-2010, 07:35 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Thumbs up Great job!
Good job on the post and taking the time to take photos of the work - it keeps us all out of the $tealer$hip
Old 07-05-2010, 02:32 PM
KJI3jflarryfe93's Avatar
Yo broe!
U forgot to post weekly updates of your homefix!
Does it work properly now?
No lcd fading digits?
Keep this thread alive pleez.
I might du de same ting u did and trying to fix my on N off dissapearing digits.
Old 07-05-2010, 02:51 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Originally Posted by kowalski
Yo broe!
Yup it still works.... I pulled mine back out and replaced the bulb, since I did the fix I have driven over some rough roads and everything still works great. I suggest you try this if your LCD isn't working correctly, mine was pretty bad and I was skeptical if what I was doing was even going to work but it did and I am HAPPY with the results. The whole thing took me less than 30 minutes and most of the time spent was figuring out how to take it apart and how everything worked. I could do it in less than 15 minutes now that I have done it before. The pics I took should make it pretty easy for anyone trying this out. GOOD LUCK
Old 07-05-2010, 03:12 PM
DRBC43AMG's Avatar
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Great work
Now if you got your white coat on for the sun slider...
Old 07-05-2010, 04:05 PM
you just unplugged the flatwire from circuit board, took most of the parts apart, then just put them all together?
No gluing or greasing needed?
Did you have to reinforce any of the connectors to give better electric conection to the display that fades out?
You are Macgyver, yes?
Mr. Goodwrench.
Old 07-05-2010, 04:24 PM
Mr. Goodwrench.
No glue or grease just plug and play.... I made sure all of the star screws were TIGHT, that will help keep the connection between the LCD and the ribbon cable.
Old 07-05-2010, 04:51 PM
  #32
Ok, härlich das ist gut!
Vielen dank.
Thanx man.
Old 07-05-2010, 04:53 PM
  #33
Vielen dank.
Thanx man.
veel succes
viel gluck
held og lykke
lycka till
Old 07-06-2010, 05:01 AM
  #34
DRBC43AMG's Avatar
Looks like we need to start speaking multi languages soon on this forum
Old 07-06-2010, 05:27 AM
  #35
veel succes
viel gluck
held og lykke
lycka till
I see you know:
lycka till = swedish
held og lykke = danish or is it norwegian?
veel succes = dutch
viel gluck= german
dang you are high IQed
Old 07-06-2010, 06:28 AM
  #36
DRBC43AMG's Avatar
I see you know:
veel succes = dutch
viel gluck= german
Specially when he wears the white coat that's when he puts his fingers.... on the screws
Old 07-06-2010, 10:43 AM
  #37
I see you know:
veel succes = dutch
viel gluck= german
Danish, but don't be fooled...... that is about as much danish, swedish, and dutch that I know
Old 07-07-2010, 01:06 AM
  #38
Jovsky's Avatar
2000 C230 Kompressor Sport
I envy 503C43 ////AMG how he can fix his car on his own.
How I wish I could do the same on my car. I have the fear of taking things apart and not being able to put them back together again.
Old 07-07-2010, 02:03 AM
  #39
Don't be fooled, I am scared to death as I do it The scariest for me yet was the gear display in the shifter and the shift linkage. Once you get everything apart there is a lot to go back together. The trick is I take a photo before I move to the next step.... A picture is worth a thousand words + it helps for my detailed write ups
Old 07-07-2010, 08:34 AM
  #40
Well said Mr.Braniac!
We should be very happy knowing you and your superexpertise knowledge on this forum!
I haven't reached the high mileage on my car yet, the mileage when the car begins to break down!
I pray to god I'm good to go for another few years without any major repair expenses.
Old 07-17-2010, 01:31 AM
  #41
UPDATE:
Just wanted to let you guys know that the LCD screen fix is still working great
Old 07-17-2010, 04:41 AM
  #42
DRBC43AMG's Avatar
Guess you found the perfect fix
Old 07-25-2010, 03:47 AM
  #43
TPWUK's Avatar
2000 CLK430 Convertible
Great write-up on your the repair.
My CLK430 has developed the same fault. The climate control module is dual zone though, do you think the repair will work for me too?
Cheers
Old 07-25-2010, 10:04 AM
  #44
Cheers
It's worth a shot..
Old 05-04-2011, 03:47 PM
  #45
Hard_Justice's Avatar
w202
Thnx for this great post! Unit work perfect now! You are the best
Old 05-04-2011, 06:42 PM
  #46
Glad I could help!
Old 08-06-2011, 09:59 AM
  #47
silver50's Avatar
2002 R230 (Sold) 2000 SL Edition 320
My 2001 R129 model SL also has the same unit. My thanks also for the info here, I had a go today.
However, I thought I should add here that the little screws that hold the circuit board on are actually smaller than mentioned above. It says they are an SD10, I think they are only one size down from that but two sets of them I had only went as small as a 10 which was pretty frustrating having split the unit (not intended as a dig at the otherwise great info).
So make sure you have very very smal torx style bits to hand!
I got someone to help so fingers x'd my unit keeps working. Couldn't believe the price of a new one, I priced it this week- £550/$600+!!
Old 08-06-2011, 10:27 AM
  #48
it looks nasty when the digits fades away.
this is a common problem for w202 cars, and an expensive part to replace
Old 08-06-2011, 12:29 PM
  #49
I'm glad this thread could help another member FORUMS FTW!!!
Old 08-07-2011, 05:47 AM
  #50
DRBC43AMG's Avatar
Jason,
Mine has started to do the disappearing act also. I gently tap the side of the control unit and the numbers reappear (for the moment). Do you think the unit is going out?
Quick Reply: Climate control unit
