Running with or without pads
Anyone have any issues running without pads? Any noise or problems I might need to worry about?
Thanks in advance for your input.
cheers
the springs do not work linearly and you will have moved the starting point outside of any recommended spec. I wouldn't be surprised if you have increased rubbing and crappy handling vs. just runnin the right springs.
on euro c43's like my car I have 9 mm pads all 4 corners.
I think my car is still a tad high and could be dropped an inch or 2?
I hope I don't get any rub by using 5mm front and 9mm rear?
if it is that thin, I don't it affecting the spring rate significantly.
For W202 mid 96-99
Front(W210 part number) :
210 321 01 84 pad#1 5 mm
210 321 02 84 pad#2 9 mm
210 321 03 84 pad#3 13 mm
210 321 04 84 pad#4 17 mm
210 321 05 84 pad#5 21 mm
Rear(W210 part number) :
210 325 01 84 pad#1 5 mm
210 325 02 84 pad#2 9 mm
210 325 03 84 pad#3 13 mm
210 325 04 84 pad#4 17 mm
For W202 mid 96-99
Tristan will be signing the papers this week. So picked up? Not yet!!!
BUT! If everything goes well with him getting the paper work back to Texas by Friday then I will be a plane to Chino California this Saturday morning to bring her home. Side note: What really sucks is I am moving to Manhattan Beach in Feb of 2011! So ill be driving her back her and then the DOD will be paying to have her shipped all the way back. Oh well. At least on the trip back I wont be putting miles on her. Can't wait to live sea side, like so many others here!!
Sorry about Thread Jacking...
On topic- I would go with 5mm pads as lowest out front and get H&Rs. There are some pretty amazing pictures in the pix sections of this set up with 18's and its as low as you can go w/o major rubbing issues.
