"Its back!"
Old Jun 26, 2010 | 03:22 PM
drache's Avatar
1997 C36 AMG
"Its back!"
Replaced pre-cat O2 sensor last week after pulling up bank 1 sensor 1 low voltage code. Replaced with a Walker sensor from oxygensensors.com. A week later the code is back. Tested the sensor with a code reader and the voltage varied from 0.85 to 0.05 volts. Could it be a bad replacement sensor or should I just have gone with a Bosch sensor in the first place.
Any suggestions. All input is appreciated.
Old Jun 26, 2010 | 05:05 PM
KJI3jflarryfe93's Avatar
go with bosch.
it's a better quality part.
Walker doesn't fit an AMG!
Old Jun 26, 2010 | 05:38 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Originally Posted by kowalski
go with bosch.
Agreed... you should always go bosch, if its good enough for mercedes and AMG then it's good enough for me. I am of the mindset that it's worth doing right the first time even if it's a little more expensive, you will usually avoid redoing the job later.
Old Jun 27, 2010 | 01:34 AM
MarcusF's Avatar
2002 CLK430
The sensor tested good, but the wiring may be bad. How old is the harness?
Old Jun 27, 2010 | 02:13 AM
indeed, didn't even notice that it was a C36. Check the harness....
