Where to source a 5.4L???
Old 09-06-2010, 08:31 PM
  #51
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Originally Posted by LantanaML320
Is this about a normally aspirated 55 or supercharged 55? Normally aspirated would be VERY simple and not expensive! Mechanically you just bolt in in as there is nothing really mechanically different from the 4.3. If you want a properly tuned normally aspirated 55 I would suggest using the ECU from a CLK55. It can be unlocked and programed to the car with STAR DAS in developer mode. Enignes are on Ebay all the time.
M113 5.4L is what I am after- n/a 55. I guess one of the guys who did the 55 swap is having trouble tuning his stock C43 ECU, so your suggestion of sourcing the ECU from a CLK55 is probably right on the money. Of course that's going to add to the total cost as well as headache of the project I'm sure. SAAB PM'd the contact info for the 55 motor but alas they are not open on labor day (of course) so I will be contacting them sometime this week to get a quote on an engine and see if they have an ECU to boot..... Thanks for the input
Old 09-06-2010, 09:49 PM
  #52
LantanaML320's Avatar
2004 Chrysler Crossfire
The ECU issue is not that expensive, but it is just tough to figure out. You can get Used good ECU's for under $200 and it costs $250 to have it ulocked. A guy I know would probably charge a couple hundred to program it and that can be done remotely over the internet as long as you have local access to an independant shop with MB Star DAS. You won't find a mechanic that can do this themselves. But all the shops know Beckman Technologies and buy used ECU from them. Replacing an ECU is easy but programing an engine to a whole different car that didn't come with that engine takes Developer Mode which most mechanics can't do if they have even heard of it.
Your first step to see if this approach would work is look at your ECU and get the part number that begins with the letter "A". And then then check the part number off a CLK55 computer and see if they are at least the same type such as ME 2.0 or ME 2.8 I can do this if you need me to. I have all the MB software and can check it fairly easily. As long as you are using the same type of ECU 2.0 vs 2,8 things will be fairly easy.
Old 09-06-2010, 10:10 PM
  #53
WOW you have been an incredible help and knowledgeable source of information. I will post what I find out this week after I can contact the yard with the motor + source an ECU.
Old 09-06-2010, 10:19 PM
  #54
Saaboteur's Avatar
eclectic assortment of cars
From what I understand, you don't need to swap in an ECU either. Speedybenz told me that the stock ECU has enough adapability in it to handle the 55 engine.
In Money-One's case, I can see why he is going with stand alone. It's fundamentally the same issue I had on my old Saab with the stock Bosch LH fuel injection and old skewl distributor ignition - crank up boost plus loads of other mods, and you can't tune it precisely enough. Stand alone - whichever system is used - can be a pain to install and tune (especially the light throttle, cold start stuff, ie. the everyday boring stuff) but the rewards with the flexibility for performance can be worth it. Depends what you want. I like the plug and play that AEM does with their systems - literally plug and play with the ECU and tune with laptop, using all factory sensors - but their application list is understandably limited to the more popular tuned cars, typically Japanese. Clearly, a C43 is not on that list. If it was, one would go that route for the ease of installation. Lemme tellya, measuring a crank pulley or flywheel to place magnets and then installing a crank sensor can be time consuming - not to mention nerve rattling when firing up for the first time!
Old 09-06-2010, 10:58 PM
  #55
No thanks..... I think I'll pass
Old 09-07-2010, 07:49 PM
  #56
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Originally Posted by Jovsky
From the difficulty level 1-10, and 10 being the hardest, how difficult would it be to swap the motor with the 5.4L? Do you really need thorough knowledge and capability as one member claims?
If you r mechanically inclined and have the tools ,the swap is pretty straight forward.
Old 09-07-2010, 07:52 PM
  #57
ProjectC55's Avatar
WOW, apparently I don't spend MY money fast enough for you guys. What about my posts make you guys think I am not serious about my car?? I like to look at every option before I drop my hard earned money on components for my car.
My original plan was to do the swap AFTER my 4.3L went kaput, I only have 111k on it and it runs GREAT.
. Sorry to say dude but unless you run her without chging your oil or without putting in oil that 4.3L motor is not going Kaput anytime soon in your lifetime.
Not necessary. I've been thru all of that. The stck AMG ECU in the C43 will work just fine. Just drop the motor(5.4L) in and turn the key that's it. It's no where near as comlicated as everyone's making it seem. Plus you did yours from a V6 and you did a very good job. In your swap you should have only had to chg the engine wire harness as far as the wiring was concerned right?
Nice job on that Crossfire by the way.
Old 09-08-2010, 01:11 AM
  #58
Originally Posted by ProjectC55
. Not necessary. I've been thru all of that. The stck AMG ECU in the C43 will work just fine. Just drop the motor(5.4L) in and turn the key that's it. It's no where near as comlicated as everyone's making it seem. Plus you did yours from a V6 and you did a very good job. In your swap you should have only had to chg the engine wire harness as far as the wiring was concerned right?
On the Crossfire, I used the donor engine, wiring harness and ECU. I did have to change a few wires that I had to match to the car by function. The only tough part was getting the MB computer programmed to the car. That has been figured out and it opens the doors to all kind of possible swaps.
I did do some checking and what I said earlier about the CLK55 ECU was incorrect. the C43 uses the ME 2.0 computer and the only 55 that uses this computer is the pre-2003 E55. If the C43 mapping works great on the 55 then great. If someone wanted to have the actual 55 computer it would be fairly easy to program an unlocked used E55 ECU to the C43 using the approach I mentioned.
If someone want to use the 55K engine in a C43 your are going to have real problems to work out and will probably need a AEM piggy back system working with the stock C43 ECU. If anyone wants the number of the guy who will can program a used ECU for an engine swap, PM me.
Old 09-08-2010, 11:12 AM
  #59
Guys check this out. It is short but it is a highly modified SRT/6 (supercharged AMG32) taking on a yellow Crossfire with a 55 Kompressor engine swap.
http://www.youtube.com/watch?v=jEdhI...layer_embedded
Old 09-09-2010, 11:55 PM
  #60
Jovsky's Avatar
2000 C230 Kompressor Sport
Found this 2006 E55 Engine with 30k miles on Craigslist for $4,000.
http://losangeles.craigslist.org/sfv...945761544.html
Old 09-10-2010, 12:15 AM
  #61
Jovsky's Avatar
Found this on Craigslist: 2002 Mercedes Benz E55 , 145k miles, $6,995.
Link: http://losangeles.craigslist.org/sfv...935793219.html
Old 09-10-2010, 02:12 AM
  #62
2006 E55 is supercharged I believe, whole different type of swap
Old 09-10-2010, 02:14 AM
  #63
way too high of miles, it has more miles than my C43 by a little over 30k and it's 3 years newer. Makes me wonder if it has a clean title..... Good price though.
Old 09-10-2010, 09:06 AM
  #64
Jovsky's Avatar
Is a supercharged 5.4L a different engine type than a 5.4L n/a? Also, is supercharged 5.4L harder to swap than the 5.4L n/a?
Old 09-10-2010, 09:40 AM
  #65
Yes, they are differnt in many ways. First they have a lot more power. They use speed density instead of mass air flow and cannot be controlled wit your stock ECU. The stock ECU cannot read or deal with boost. It can be done but you would have to run the 55K ECU which is a Bosch ME 2.8 and the C43 uses a ME 2.0. Using an AEM piggy pack computer with your stock ECU may work. It will bolt right in like a regular 55 but the electronics become the hard part. I did a v6 to V8 conversion and a friend just did a v6 to to 55 Kompressor swap. In the process we learned how to reprogram a donor ECU to our cars but we have not tried a 2.0 to 2.8 ECU swap. It is probaly possible.
Old 09-10-2010, 11:51 AM
  #66
blackbenzz's Avatar
haters crazy
Can someone local check this out for me? I sent an email and haven't received a response yet. If this is legit I want it
Old 09-10-2010, 04:37 PM
  #67
Here is a good candidate.
http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
Old 09-10-2010, 06:04 PM
  #68
Saaboteur's Avatar
I just did an eBaymotors search too. What a wide variety of pricing! $10k+ on the high and unrealistic side. More reasonable in the $2500-4000 range.
Old 09-10-2010, 08:01 PM
  #69
Jovsky's Avatar
Try calling the tel. number on the ad.
Old 09-10-2010, 09:04 PM
  #70
blackbenzz's Avatar
haters crazy
I did. Noone picked up and the answering machine just says the phone number. Would want someone to physically check it out before spending $4k
Old 09-10-2010, 10:46 PM
  #71
Jovsky's Avatar
Might be a scam since they are not picking up the calls and not replying the emails... Very unprofessional IMHO... Just forget about the ad...
Old 09-11-2010, 10:59 AM
  #72
C280 Sport's Avatar
MB’s
Old 09-11-2010, 12:46 PM
  #73
tasho3's Avatar
2014 C63 Sedan
here you go
https://mbworld.org/forums/clk-class...55-engine.html
Old 09-11-2010, 01:04 PM
  #74
blackbenzz's Avatar
haters crazy
Originally Posted by tasho3
There was no 99 CLK55 and it clearly states in the description it is a 430 not a 55
Old 09-13-2010, 12:03 AM
  #75
MarcusF's Avatar
2002 CLK430
In addition to this, many of the hard parts differ. The parts catalog shows the 55K as using different rods, pistons, block, crank, heads, and cams. Same part number on intake valves though. Do the NA 55's use dual valve springs?
Quick Reply: Where to source a 5.4L???
