C43 '55' swap thread
#601
your car ownership is very fortunate and cheap.
congrats.
goverment in my country consists of enviromental fascists!
these nasty people are working hard choking us cars owners slowly with hefty taxes for fuel, annual car tax, road tax, number plate tax, annual vehicle inspections.
soon the government fascist will implement tax for us people breathing air and cows farting causing carbon dioxide pollution.
yikes!
congrats.
yikes!
#602
dont think so, i saw factory option wasnt available for 202033 but the kit i got from curt fits my car's chassis so everything was peachy perfect!
#603
1999 C43 AMG, 2005 E55 Wagon
Mine has had a tow assembly on the back since it was new! I don't have a pickup so I'm always on the lookout for a small, low trailer i can use.
55 motor plus the same driveline from the w163 so it should be fine towing a lot of weight!
my tech friend used his w163 ML320 to tow MB cars for 10 years and never had a failure. These are way tougher than they seem.
#604
Here in America we do whatever the f we want! Cats, air pump charcoal canister? Yeah right no thanks Obama! LOL.
Here's one that spun off right from here mbworld. Some Nissan guy talking smack so dude waxes him with his E55. While pulling his lawn mower! Murica.
#605
https://youtu.be/eYxwgmACJMY
#606
did it come from an ML55?
was tranny matching numbers with the 55 engine?
the w163 tiptronic tranny, das it shift smooth and correct compared to your stock tranny?
what stall speed converter/TQ converter did you use when you had the new tranny installed to your car?
#608
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I wonder how the transmission from an ML will fit without major surgery, both mechanical and electronical, as it's built for a 4wd....
#610
Its the same transmission, 722.6, but with an added transfer case for th 4matic. They are 2 different components. The difference between the 722.6 in the cars vs the w163 is how the casing is designed around the output shaft to accomodate the transfer case. Sorry it if sounded like I put one in my car, because i never meant to imply that.
#611
Thats only because of our open govt. laws EVERYTHING is open and publicly available. at times its pretty weird but its pretty funny being able to call someone out who says they never speed by printing out their tickets for them to see.
nkctb7 (06-11-2017)
#612
Changing out the wiring harness, lower oil pan and tb. Cleaned up my steering pump, ac condensor, fan and lower oil pan. After inspecting the oil pan, it appears that the S55/CL55 oil pan on this new motor is identical to that of the C43. Here's a few pics.
nkctb7 (06-11-2017)
#614
00 C200 & 00 C55 & 06 SLK55
As i know; MB made their first production of (oct/00 to dec/05) "W215/W220" SMB46 N/A M113 with same production of
(sep/98 to nov/02) "W208/W210" SMB39 lower oil pan..
-;ZAYED;-
-;ZAYED;-
#617
I was able to snap a pic of the underside of the mounted motor. The '02 S55/CL55 oil pan is in fact the same part #112 014 06 03 as the C43 oil pan. Attached are both pics with the first pic taken of the '02 S55/CL55 oil pan.
#619
D.,
The "W215/W220" lower oil pan should be the same with "W202/W208/W210",
the upper one is different, due to a differ oil pump between them..!
-;ZAYED;-
-;ZAYED;-
#620
Check everything again exactly.
A friend of mine swap the 5.5 from a CL in its C43. At the installation, however, he had to realize that the oil pan of the CL55 engine is 5cm longer than the C43 engine, although they look the same.
Wish you a lot of fun with the installation
#621
I went to my friend garage today, he got "3" Engines,,
(2) 02 W220 Engines:-
one Engine with code#: "033A416", same lower oil pan with "W202/W208/W210",
but the other Engine with code#: "036A518", lower oil pan won't fit with "W202/W208/W210",
(1) 02 W215 Engine, code#: "036B227", lower oil pan won't fit with "W202/W208/W210",
*that definitely depend to the Engine countries spec.,,
or at least, depend to the factory production line limit of those oil pans..!!
-;ZAYED;-
-;ZAYED;-
nkctb7 (06-12-2017)
#622
-;ZAYED;-
-;ZAYED;-
I still need to swap out the upper oil pan. Correct? Thx Z
#623
Most welcome D.,
yeah, upper oil pan should to be changed, due to a differ oil pump,
as i remember; "W215/W220" oil pump is way smaller (filter neck carving), than W202/W208/W210" one,,
*"W202/W208/W210" oil pump #: "113 180 04 01"
*"W215/W220" oil pump #: "113 180 07 01"
-;ZAYED;-
-;ZAYED;-
nkctb7 (06-13-2017)
#624
For those that are interested and curious as to the differences in 55 motors. The new 55 motor is a 2002 S55/CL55 motor. Big thank you as always to Zayed who is a world of information and always there to help!
As it stands, there is a big difference in the oil pump neck as the pics will show the difference in angle and length. After removing both pumps, the neck plate itself can be swapped out provided that both have 4 torx bolts. Zayed already knew this and stated that it may be possible to keep the upper oil pan and oil pump gear if the neck is a universal fit although he did say that the lower pan may hit the swapped out oil pump neck. He was correct and in fact it does hit. The upper pans are literally a quarter inch different.
Thanks Z! Once again you're a saviour!
