Sprint booster for C43
Sprint Booster modifies the signal between the accelerator pedal module and the electronic throttle body. This modified signal forces the throttle body to open 'more' than the stock signal at a given pedal position. In effect, the idle-to-full-throttle pedal travel is reduced. This makes your car 'feel' more powerful because a given pedal input produces greater throttle opening. This is especially evident in the low to mid rpm range where most cars spend their time on the street.
Sprint Booster simply modifies the throttle signal between the accelerator pedal and the throttle body. Big deal right? Keep in mind, this is the same concept as the 'throttle pulley' modification on cable based throttle systems - which was very popular in it's time. It doesn't add horsepower, but makes the throttle more sensitive and makes the car 'feel' faster.
It doesn't matter if you have a Sport Mode, ECU software, or 'Chip' on your car, Sprint Booster works independently of other modifications. It simply makes the throttle more sensitive, making the car 'feel' faster.
Is Sprint Booster for everyone? Of course not, no performance product ever is. If you have a track car where you spend most of your time near redline, Sprint Booster is not for you - Sprint Booster benefits are felt in the low to mid pedal travel. Some people don't like the fact that Sprint Booster reaches full throttle before full pedal travel - if you routinely mash the throttle to the floor, Sprint Booster may not be for you.
Sprint Booster is most effective in the low to mid rpm range, which is where most 'street' cars are driven on a daily basis. Yes, you may need to adjust your driving style after installing Sprint Booster - but that is a short learning curve. Sprint Booster will put the 'fun' back into your daily drive.
Sprint Booster is simple but effective - it makes the car more responsive and thus more 'fun'! This is why the product carries a 30-day money back guarantee!!!
Sprint Booster installs in minutes, and is easily removable. Plug-n-Play performance!
Here is the website:
http://www.sprintboostersales.com/index.htm
from what i recall. you only notice it the first few couple of days but when you get used to it, its like it isn't there.
There is no shortage of current and active discussions about our product. But those who try it generally love it. Those who haven't are suspicious and are critical. We do understand this, and this is why we allow for a 30 day NO B.S. return policy. If you aren't blown away by the difference or just dont think its worth it, you can return it. Its that simple.
Here are recent discussions from all over the internet. Feel free to do a google search as well to find even more. Like we said, those who try it, love it.
Porsche
http://www.planet-9.com/reviews/caym...t-booster.html (founder and admin)
http://www.planet-9.com/cayman-boxst...tml#post484930
http://www.planet-9.com/cayman-boxst...installed.html
Mazda
http://forum.miata.net/vb/showpost.p...3&postcount=17
6Speedonline
http://www.6speedonline.com/forums/9...ml#post2832536
http://www.6speedonline.com/forums/9...ml#post2967798
http://www.6speedonline.com/forums/9...ml#post2950088
http://www.6speedonline.com/forums/9...ml#post2953256
http://www.6speedonline.com/forums/m...ml#post2890671
http://www.6speedonline.com/forums/m...ml#post2900491
http://www.6speedonline.com/forums/m...ml#post2905706
http://www.6speedonline.com/forums/c...ml#post2420579
mini / bmw
http://www.northamericanmotoring.com...t-booster.html
jeep
http://www.jpmagazine.com/techarticl...tor/index.html
http://www.jeepforum.com/forum/f96/d.../#post10110329
Audi
http://www.a5oc.com/forums/showthrea...109/index.html
http://forums.audiworld.com/showthre...sprint+booster
VW
http://www.golfmk6.com/forums/showpo...3&postcount=10
Domestic
http://www.challengertalk.com/forums...booster-20352/
350z/370z
http://www.the370z.com/engine-drivet...z-7-speed.html
http://www.the370z.com/573162-post12.html (Kyle from Stillen)
http://www.the370z.com/720522-post11.html
http://www.the370z.com/nissan-370z-g...booster-2.html
Here is the email they sent me when I asked if they had a sprint booster for the C43:
Thank you for your interest with the Sprint Booster.
Can you confirm that your 1999 C43 AMG has the drive-by-wire throttle system? Does it have an electrical harness to the accelerator pedal module, or is it controlled by cables?
If it is DBW, then the Sprint Booster should work.
Best regards,
Ken
Best regards,
Ken
http://www.sprintboosterusa.com/t-dealers.aspx
C43, just unplug the 6-pins acceleration sensor connector (located front of the brake booster), connect the sprint booster plug to the
accelerator sensor directly, it well immediately work, it has "3" options:
A) Green light = smooth driving with 30% more throttle response (daily use) which i prefered
B) Red light = Aggressive driving with 70% more throttle response (hard racing use)
C) No light = not working (factory use)
ZAYED,,
I can tell you it does work with our cars and you have 2 options. the regular one and the AMG version. Supposedly the AMG version is less aggressive due to the extra aggression AMG has programed into it. I was told the non AMG version is MUCH more aggressive when put on an AMG vehicle.
One thing I like is the new version has the 3 settings like cm60k posted about.
Here is a link to the site:
http://www.sprintboostersales.com/de...%20or%20Diesel
Gotta love this quote from the website: "Sprint Booster puts an end to your AMG's poor performance once and for all". Just think of all the unfortunate AMG owners who are getting "poor performance"
..The link says 2000 and up AMG models.So im taking that this will not be applicable to our 98-99 C43's?..Or since we do have the pedal sensor this will work.Correct me if I am wrong.
I will be picking up a sprint booster eventually...
Hey Sal,
Looks like you need to modify your signature as it states you have the Renntech CF air box, which you no longer do (ask me how I know
ZAYED,,
In the MINI it installs down to the accelerator pedal and has a switch inside the cabin to easily change between settings. I turn it on when I want crazy responsive driving, and off when I just want a more relaxed drive.
Mashing the throttle is NOT the same as using this device, I can't explain it, but it just feels crisper, more responsive turned on.
My only wish is that they had a custom adjustable version where you could set the % of the throttle amplification.
Jason
