For the true carbon fiber junky
One of our good friends, Rory Craig, who is a student at the Art Center College of Design, has designed a sweet carbon fiber baby car seat prototype. He developed the prototype as a Sparco product (and is trying to pitch the concept to them), with the idea of a race-inspired child seat for those car enthusiast fathers that want to get their kid a really unique baby seat.
All straps are Sparco race harnesses and all plastic insert and parts were made using rapid prototyping machines. Interior is fully padded and snaps out of carbon shell for washing. The many holes down the back of the seat allow for harness adjustment as the child grows.
In the past we’ve written about Weds 100% carbon fiber wheel, but this is not something that is used in production at this time. Currently, the only real option I know about for a real carbon fiber production wheel is from Dymag, which features a carbon fiber outer rim, and a regular wheel face with magnesium hub. That’s about to change.
The new carbon fiber wheel is in the final stages of development, and expected to hit the streets in January of 2009. You’ll be able to find them in both the 590R and 890R styles, which feature forged aluminum centers with titanium hardware. They will initially be available in both a 19″ and 20″ wheel, and can be expected to cost $2,500-$4,000/wheel ($10,000-$16,000/set), although final price is yet to be determined.
Wet Carbon Fiber vs Dry Carbon Fiber
Carbon fiber parts are very popular nowadays. There are carbon fiber hoods, carbon fiber trunks, carbon fiber tops, carbon fiber mirror covers, etc. Moreover, there are a lot of brands manufacturer carbon fiber parts, for instance, SEIBON, VIS, NRG, Carbon Creations, etc. If you are getting carbon fiber parts for your car, you might get confused by so many options on the market, as well as so many brands. In fact, it is good if you can read this article to learn more about carbon fiber before you do your purchase.
First of all, we should learn about what exactly Carbon Fiber is. Carbon Fiber, also known as Carbon Fibre, gets its name because it is actually consist of very thin (about 0.005 – 0.01 mm in diameter) carbon atom fibers which bond together in microscopic crystal aligned parallel to the long axis of the fiber. This crystal structure makes carbon fiber very strong, yet carbon fiber has a lower density than steel. Carbon fiber is very strong when stretched or bent, but weak when compressed or exposed to high shock (eg. a carbon fiber bar is extremely difficult to bend, but will crack easily if hit with a hammer). With this properties, we can apply carbon fiber to make car parts that is strong yet light weighted. However, the cost for carbon fiber is much expensive than materials we are using for car parts, i.e. fiberglass, plastic or steel; therefore, carbon fiber parts are consider as a high end product in auto industry.
Now, after explaining what carbon fiber is, we will tell you the two kinds of carbon fiber products on the market – Wet carbon fiber and Dry carbon fiber. Wet and dry carbon fiber are manufactured in different process. Generally speaking, dry carbon fiber is better but it is 3-4 times more expensive than wet carbon fiber.
Dry carbon fiber is made in a pre-preg and dry process which consists of vacuum forming sheet of carbon fiber into a mold at temperatures around 350 Kelvin. This process allows carbon fiber to form into a strong and lightweight composite. Moreover, since dry carbon fiber consists of vacuum forming carbon fiber sheet, dry carbon fiber surfaces are smooth and show no air bubble pockets.
Wet carbon fiber is formed by using hand laid carbon fiber sheets into a mold then mixed with resin (30% carbon fiber, 70%resin). This process may allow air bubble form inside, then makes the wet carbon fiber structure weak and also is susceptible to changes in temperature.
In conclusion, the weaves and quality for dry carbon fiber are more consistent but they are 3-4 times more expensive than wet carbon fiber. In contrast, wet carbon fiber might has little defects like wavy weaves and tiny bubbles, however, they will be selling at a more affordable price. Most aftermarket carbon fiber parts like SEIBON, VIS, etc are using wet carbon fiber.
Although dry carbon fiber is a better production, it might be expensive to get all dry carbon fiber parts for your vehicle; moreover, if you are getting brand name carbon fiber parts, the wet carbon is in very good quality actually. Therefore, based on your budget, you should pay attention to what you are getting.
Dry carbon fiber trunk picture
Dry carbon fiber grille picture
Dry carbon fiber engine cover picture
Dry carbon fiber roof picture
Dry carbon fiber picture
Wet carbon fiber hood picture
Wet carbon fiber parts picture
Wet carbon fiber console picture
Carbon Fiber at home New technologies in Your home! If You can’t afford a supercar with carbon fiber seats, buy something what can bring You even more fun – carbon fiber toilet boil! Stylish **** for only 1k$.
more
But if 1k$ for the toilet boil is too much for You, take the cabon fiber toilet seat. Costs only 229$ and is avaliable at dynamiccomposites.com.
