C43 front bumper brackets
Would brackets of a regular 202 work for our cars????
I need mine replaced in the front. Car got clipped while I was in class and my bumper was hanging almost half way down. ***** ran away didn't even leave a note
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I would think that all the bumber attachments would be the same for all W202 models, but I stand to be corrected
if it's fuc--- up by an hit n run SOB, then get your self a new bumper instead.
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
The bumper brackets are attached to the bumper reinforcement, you will need a new one. Yes it is the same for all W202's but you might need to alter it a bit to fit the C43 bumper skin. From the dealer it's around $200 and it a fairly easy swap.
HPS C43 AMG, E36 M3, MK3 GTi VR6, 66 FORD F100, 85 FORD F250, 04 GSXR
I thought the bumper holders/sliders were bolted to the rebar?? I found replacement ones for about $11-14 per side. I need a new one on my drivers side as well.
Guess prices went up a little bit.. $12-25
http://www.google.com/#q=c43+bumper+...8f35a77978fbf6
You are correct about the bumper brackets. I was referring to the piece that holds it onto the brackets themselves. I would imagine that this is the piece that is damaged and needs to be replaced. I pulled my bumper off to realign it and noticed mine were cracked, apparently this is a common issue.
If you pull your bumper off you can see it is connected by a large piece of polymer (plastic) that is clipped to the bumper skin. On this piece are the brackets that slide onto the bumper brackets you are talking about. The brackets on this piece are the ones I speak of, it is common for them to crack over the years allowing your bumper side to "flare" out to the sides.
I figured that's what you were talking about...the typical German bumper setup.
