Timing Chain Replacement C43?
Old Nov 2, 2010 | 10:43 PM
SparksterC43's Avatar
2008 ML320cdi, 2008 SL600Renntech, 2009 C63
Can this be done through the top like an old 380SL or do you have to pull apart the front of the engine?
Thanks in advance for any help
Old Nov 2, 2010 | 11:02 PM
ohlord's Avatar
Double roller
rarely fails.
Got problems?
Old Nov 2, 2010 | 11:13 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Simple job, replace the tensioner while you're there. You can feed in a new chain like on a 380. Remove both rocker covers to do it, on a v6 the balancer shaft must also be aligned, not an issue on the v8's though.
Old Nov 3, 2010 | 08:22 AM
Thanks guys, I am not worried about failure, but it is starting to make some noise at idle, so wanted to replace.
Old Nov 3, 2010 | 08:54 AM
DRBC43AMG's Avatar
What's the mileage on the engine?
Old Nov 3, 2010 | 09:08 AM
218K
Old Nov 3, 2010 | 12:04 PM
DRBC43AMG's Avatar
Understandable at that kind of mileage
