Rattle from muffler: SOLVED!!!
probably leave the primaries alone and remove the secondaries and resonator.
I haven't heard what the system sounds like on an actual C43 yet, very interested to know! I'm hoping the supercharger will only add a little more groan along with the V8!..and hopefully I'll be able to get a little more HP out of the setup as well.
I know shops don't typically remove cats in the US, but if there aren't O2 sensors there and if the primaries are still installed, do they care so much? Have any of you guys had issues getting them removed?
I bet you will be able to find someone that will do it. It is your car after all and you can tell them your using it for the track only. Im sure some will give you trouble but just keep looking around.
