esp abs lights
esp abs lights
Lets try again, my eps and brake abs lights are on, I checked the codes and there is none,
Come on guys give me a starting point here i have searched what few forums I know but seems like they are none existant on repairs
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Have you tried disconnecting the battery for some time to "kill" the memory?
1995 C36 AMG, 1998 C43 AMG
Just go get it StarRead. I'm sure a local Merc indy will be cheaper than the dealer, but thats the only way to read the codes for anything other than a CEL. Once you know that you can pinpoint whats wrong. There are codes there, you just cant access them with OBDII, only the StarReader
Start by
changing you brake switch.
16bucks autohausaz.com
Have you recently changed your battery or unhooked it?
If so reset the steering wheel angle sensor
then replace the brake switch.
This is such a PITA but with these cars you have to reset the angle sensor or everything goes nuts! This happened to me with my Audi after I replaced a control arm!
IIRC you turn the car on(might be position three before start?) and then w/o driving it at all your turn the wheel right to lock and hold for 10 seconds, then turn the wheel all the way to the left lock and hold for 30 seconds. Do this thrice and you should be set.... If not then search it and see. This was how I did it in my W210 a year ago and I dont quit remember how I did so. Ohlord will know with out a doubt.
Put the switch in havent really driven but when i start the car goes off and comes back on, used to just just stay on, ill try and disconnect battery later
