Leaking Coolant?
I drove 300 miles, then the next day i came to my car and i had probably a cup full or so of coolant on the ground. then i checked it but and it seems to be leaking from the drivers side near the radiator of not from it.
I turned the engine on and off etc. and it doesnt leak while i drive. There seems to be a red pressure valve on the bottom of the radiator and maybe its comming from there. its only in little amounts after im done driving
ill look.
also yea i know heat is bad the coolant isn't That low at all, its just little by little after each time i drive.
